using the loader to dig Holes for trees = EASY!
   / using the loader to dig Holes for trees = EASY! #11
Nice Job with the trees and machines - just a thought you might want to make mulch mounds (with cloth) around the tree's since the impact area is large enough per tree base.
I actually have to plead with some of my guys to allow me to use my machine on root balls that size. They bang out the hole in no time, with little impact to the area. Of course they allow me when its they start getting larger (diameter)
   / using the loader to dig Holes for trees = EASY! #12
Looks Great! Anything to keep the shovel out of your hands. :)
I can't afford a FEL, do you guys think a rear mounted scoop could be used in the same way? I've never used one. Can they dig? or is it just to scoop above grade material?
I didnt take any photo's, but the trees are all mulched now, ground is so dry that I kinda 'damed' up the outter edges of the hole to help retain water. The grass is nearly recovered already on all but 1 hole (did 4 in one evening), had it not been so dry, grass recovery would have been complete on all four holes.
Tony123 you could probably use a scoop, might be harder to keep your holes square ( not tappered ), the ability of the scoop going deep would have more to do with the 3pt setup of you tractor.
DuaneW.
   / using the loader to dig Holes for trees = EASY! #14
You've got t a point. Once I get as deep as the 3ph will allow, then it is a matter of getting the tractor lower. Which means, you could use it to dig a hole that the tractor fit in, but not something like a tree hole. :mad:
I wonder how you could use a tractor to plant trees if you didn't have a FEL or hoe? or auger? hahaha I'm making it tough. Basically, I have a scoop and a BB....how do I dig a hole? :eek: :) :eek:
   / using the loader to dig Holes for trees = EASY! #15
Prolly just do it by hand...sorry:) The auger, of course would be the least expensive choice of a new implement.
   / using the loader to dig Holes for trees = EASY! #16
Nicely done...but sure makes me glad I have a backhoe.
Just one comment on the tree planting...and it may be a trick of the camera.
In your last pic, it looks like the crown of the tree (top of the root ball, where the trunk meets the ground) is below the grade of your lawn. That's too deep. You want the crown three or four inches above the grade of the surrounding lawn and you want the mulch to thin out to nothing as you move from the drip ring to the trunk.
I mention this because you brought up the issue of silver maple roots growing at the surface. The biggest cause of this is trees being planted too deep.
I just planted an Autumn Blaze maple, too, along with a Pacific Sunset maple, a sweetgum, a crabapple, a Serbian spruce and a half dozen shrubs.
It was a trick of the camera, but it was not 3-4 inches, more like 2-3 inches. If you look close at the pick, the top of the 2x4 is approx 1/2" below the top of the rootball, which is how I was told to plant them, I hope that is not to deep, what do you think?
   / using the loader to dig Holes for trees = EASY! #18
You should be just fine. Just make sure you pull the backfill back away from the crown a little, so that the original potting soil is visible at the crown. You want the crown to breathe and you want those roots reaching down for water and soil instead of up. Looks like your water ring is well outside the drip line of the tree -- that's good.
One trick I got from the place I bought my trees (and it was one I remember my dad using years ago) is to bury a piece of perforated pipe vertically next to the root ball. Then when you water, you can be sure that the water is getting to the root zone where it is needed. After the tree is established, you can just fill the pipe in and it will never be noticed. I put a landscape grate over each of mine and will use them to feed and water for the next couple of years. I was also instructed to water weekly until mid-November, start again with weekly watering in March and continue through the first year. For Fall planting they suggested using no fertilizer until next Spring, then using a spike or root zone feeder.
   / using the loader to dig Holes for trees = EASY! #19
Where are you Duane? I bought my Autumn Blaze in Ohio, and it had already started turning. Yours look mid-summer green.
I'm in central Ohio, just south of Columbus. The trees turned RIGHT after planting them and now are getting thin on leaves. Was told the same thing about watering them, 1-2" per week untill november. Right now I am using a 5 gal bucket with a small hole in it to water, takes about 5 hours to get the water all out of the bucket, do that about every other day when its been 90+, will back off once it cools down a little.
DuaneW.
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
2011 Caterpillar 299C Two Speed Compact Track Loader Skid Steer (A52377)
2011 Caterpillar...
378813 (A51573)
378813 (A51573)
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A52377)
2008 24ft...
12in x 16.5in Kubota RTV-X1140 Tires (A52377)
12in x 16.5in...
