Utility vehicle questions
   / Utility vehicle questions #41
Obviously our personal biases are coming out. ;) As mentioned, any of these mentioned will work out great.
My only experience is with the Polaris Ranger 700. I've really liked the 2 across seating, as someone else said that has turned into a major big big plus for it. The extra width also gives it more stability. With that comes the negative of needing a trailer 6 feet wide to haul the thing - many small utility trailers are 5 feet wide so if you need to haul it at times, consider that too.
But, the few times I'm a passenger on any other UTV, I feel terribly cramped for foot room or seating on the other brands.....
In a cold climate like you & I have, the gas engines seem to work well. My Ranger starts at below zero temps just great - think fuel injection is the key for that.
I remember Gators as the rather slow, practically no suspension machines they used to be. I think the newer breed of Gator will serve you well, they have really ramped up their offerings.
--->Paul
Unfortunately I know those Gators way to well. Between the 6x4 and the 4x2, they don't handle, drive or operate very well. Really wouldn't recommend those unless your doing serious work. My HPX that I have now is worlds better than the old ones and the XUV's are even better. As you mention that's my personal bias. Get whatever you want. There's a lot of difference in these UTV's so you have to find what fits you both.
Springs not here yet I still have some time to think and I'm not sure if I'm going to go new or late model used
I wouldn't get a used UTV unless you are very comfortable with it. UTV's can be abused a lot easier than tractors, buy with caution. I'd go new, but if you find a really good deal on a like new one from a farm, then a used would be nice.
Strongly agreed
   / Utility vehicle questions #43
For work, I dont think you can beat the ability of the Kubota's, however, lots of buyers shy away from them when they see the prices. $12-16K is a lot to pay for a utility vehicle. I bought my RTV900 used with 68 very gently used hours on it in 3 years which is why the guy sold it. It was perfect in everyway, just like off the showroom with a full tank of diesel for $8500 which I thought was a bargain for a now $12K machine. You really have to have a need for pulling and hauling capacity to justify the cost of the Kubota RTV, but I wouldnt trade mine for 2 of anything else especially in gasoline models. I expect my engine to be purring away long after I am gone and I just dont think a gasoline engine will do that in the other competitors models. As for starting, just a second or two of glowplugs and it fires right up, although 25F is about the limit I have tried it since it doesnt get really cold in Arkansas. With block heaters though I wouldnt expect anything different in -40F. I love the true tractor type transmission in my RTV900 and the braking I get. I expect the brakes to last me a lifetime as I hardly ever use them. IT does take a bit of getting used to to drive them as you cant just take your foot off the pedal and slow to a stop, it is more like screech to a stop if you do that, but once you learn to feather the throttle to stop, you will love it and the diesel consumption is miniscule. As for pulling, it will turn all the tires in 4 WD which is all one can expect. I cant say the belt drives will do that but my only experience is with my brother-in-laws gator. His 4 year old gator wont spin the tires with out burning the belt and it is just 2 WD. We tried to use it to drag my 6' boxblade out of the shed and it wouldnt move it, the RTV pulled it out easily in Med range, 2 WD.
   / Utility vehicle questions #44
Anyone try the LANDMASTER LM-650?
I was looking for the most AFFORDABLE UTV available in 4 WD. Made in Indiana, (USA):D which is a nice departure from the norm....
Info...?:thumbsup:
I dont doubt that the kubota Is a work horse but I'm looking for recreation/work and I don't know if I can justify that type of expense for the amount of work involved plus it can be 25 degrees here in sept/oct. November can be -25 and there will be too much snow to use it anyway so I'm looking for some thing from about April 15 to November 15 If I'm lucky then factor the two types of fuel and potential starting problem and question heavy work factor and I just keep coming back to gator
And boeing I'm with you on buying from north America I'm just not familiar with that type of machine
   / Utility vehicle questions #47
The selections are numerous and depends on your use. If you arent looking for something that will still be running after 2500 hours then go with gas. As I said, unless you really need a long lasting multi-purpose workhorse, it is hard to justify the cost of a Kubota RTV. The RTV 1100 with cab and AC/heat will run as much as a small compact car ($14K at least) and for many folks, that dont need the versatility, they can buy at least 2 UTV for that money. I wouldnt be afraid to buy used though if it looks taken care off.
   / Utility vehicle questions #48
Countryboy:
Your original post suggested that you need a UTV to haul grandkids around, drive trails, and do light maintenance work on your property. The ideal vehicle for that would be a Polaris Ranger TM, the low-buck UTV Polaris produced from 2004 to 2006. These machines are wide, durable and cheap in comparison to the 4WD models. The differential lock enables the TM to do a significant amount of off-road work, but it's not shielded for deep water and mud adventures.
The dump box works well for strategic deliveries on lawns and turf sensitive to tractor tires. During spring thaw it can work on soil a tractor will tear up because of its weight and aggressive treads.
Our Ranger is used primarily as a people and tool mover on our 107 acre property. The three-across seating is particularly useful.
The simple drive system, good suspension and excellent brakes make the TM a good vehicle for the inexperienced driver.
We've put 500 hours on my 2004 TM and posted a series of reviews of it on my blog at Walnut Diary .
Thanks for the suggestions but I'm still leaning towards the gator but I don't know which one would be right for me the xuv 620i or the 825i
   / Utility vehicle questions #50
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2014 Ford F-550 (A55973)
2014 Ford F-550...
WARREN LIGHT TOWER (A58216)
WARREN LIGHT TOWER...
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
