UV resistant air hose
   / UV resistant air hose #1
wushaw
Elite Member
Bristol Texas
Kubota L2800, 15 hp 372 Mitsubishi
Ya know I would have never thought I would ever have to worry about a air hose being UV resistant until I mounted a air hose reel where the sun shines and the hose that is on it is going by the way side fast.
What is a good UV resistant hose? Brands are welcome I don't care who makes it or what country the rubber tree it comes from.
   / UV resistant air hose #2
My hose reel came vinyl hose.It deteriorated fast in the sun then cracked in the winter.I replaced it with 3/8 goodyear rubber hose.
Bill
I was thinking Goodyear since I have a 1/4" X 100" that I have had since 89 but its life has always been inside, I just figured like everything else what once was may not still be the same and it may not be well suited for direct sunlight on a daily basis.
   / UV resistant air hose #4
Is PVC UV resistant?:D Three and a half years ago, I'd never heard of PVC air hoses, but when I bought a new air compressor, I bought two of these hoses from Northern Tool. A neighbor used them painting and got paint on one, so he bought me a new one. The paint hasn't actually hurt anything except appearance, so I now have three of them. I sure do like them, but mine are only out in the sun when I'm using them outside. One stays pressurized at all times indoors and is used almost daily; still looks good as new.
   / UV resistant air hose #5
Chem Resistant gloves we used were PVC, it is tough stuff.
   / UV resistant air hose #6
I've got about 200' of air hose that is over 20 years old and I leave part of it laying at my shop door that I work at most. It is Air Brake Hose that is rated for semi air brakes. I worked on semis for 30 years. I run 170psi in it and the only time I have a problem is if I drop something on it and cut it. Welding and cutting, even my Plasma dosen't damage it as long as nothing hot lays on it.
It is expensive but you won't have to replace it with a little care.
   / UV resistant air hose #7
I got 50 foot of napa premium blue pvc weather/UV resistant 3/8 air hose. The stuff is very tough. flexible at 20 deg. in winter, and has layed out in the sun in the summer with no ill effects. If I remember right, I have had that hose for at least 10 years. Had to replace one end cause' it got smashed:rolleyes:. I would highly recommend that air hose for flexibility and constant element exposure.
   / UV resistant air hose #9
Might try giving the hose a periodic rubdown with 303, it is good stuff.
303 Products Inc.: 303 Aerospace Protectant
Right on... a good protectant will extend the life.
Also... why not put a cloth cover over the reel to protect the hose from sunlight with a hook or peg to hold the cover when removed for use and handy to put back over the reel when not in use. The tire covers for parked/stored RV's and spare tires on the back of SUV's sure prolong the life of tires otherwise exposed to direct sun.
I have both Harbor Freight plastic hoses over 10 years old and a Good Year rubber one about 15 years old and the only repair I have had to perform on a hose was to cut 3 ft off the end of the GY rubber one and put a new fitting on it due to multiple leaks caused by the hose being in a grass fire while pressured up. I didn't notice the fire due to the welding helmet I was wearing when I started the fire with welding sparks.
Pat
   / UV resistant air hose #10
I've noticed PVC hoses in different colors. What's the difference? Is one color more UV resistant that another?
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A44571)
2007 Mitsubishi...
INOP/NON-RUNNING 2010 Ford F-450 Pickup Truck, VIN # 1FDAF4HR3AEB25362 (A44391)
INOP/NON-RUNNING...
(2) Sumitomo 11.00 R22 Tires (A44391)
(2) Sumitomo 11.00...
2005 Kenworth T800 Sleeper  CAT C15 ACERT  Ready to Work! (A46877)
2005 Kenworth T800...
40ft Pine Straw/Enclosed Trailer (A44391)
40ft Pine...
New/Unused 10ft x 20ft Single Garage Metal Shed (A44391)
New/Unused 10ft x...
