Hooked_on_HP
Veteran Member
John that is the best and simplest answer to my question. Thank You.
Bill
Bill
Gasoline engine at idle is 18-22" hg Diesel engine at idle is much less than 1" hg Gasoline engine working hard is 5-9" hg (3/4 throttle lets say going up a big hill pulling a trailer etc) Diesel engine working hard is still under 1" hg (hopefully much less as it's a sign of a clogged air filter.) Gasoline engine at wide open throttle full load is 1" hg Diesel engine at full load is also about 1" hg. jb[/QUOTE said:The numbers should have a negative sign in front or be expressed in absolute units. In ex.: -1" HG gauge=29.92-1=28.92 HG absolute at sea level. Since absolute units are not practical measure we should talk about pressure drop or differential pressure across the suction tract.
A better question for us nerdy tractor types that get all bound up in the details might have been "How much vacuum does a non-turbo diesel produce in the intake manifold compared to a gasoline engine?"
jb
ArTrvlr
Maybe you can tell us why most diesel engines need a vacuum pump to operate all the vacuum devises in autos and trucks.
