Valve leak down
   / Valve leak down #1
J_J
Super Star Member
JACKSONVILLE, FL
Power-Trac 1445, KUBOTA B-9200HST
Just to compare some valves. The valves on the PT will leak down, as every one has found out. Put your bucket as high as you can and turn the engine off. Usually by the next day, the bucket is on the ground. It has been said that PT selected these valves for this reason. I have always thought that good quality hydraulic valves should not leak down or very little. I installed a joystick valve on the backhoe that I am building, and raised the boom up in the air, over two weeks ago, it is still in the same position. That says something for those valves. The only way to get around those leaking valves, is by installing check valves. Some of the better valves come with check valves, to hold the cylinder in place.
   / Valve leak down
   / Valve leak down #3
Yes, I did notice that a lot, this weekend with the tree stump. I had to keep raising it to keep it up in the air, the tilt kept backing off.
I was thinking this was just from running the PT hard, and hot fluid thinning out. Hmmm… I didn't know that was a sign of cheap or low quality valves? I learn something new every day around here. /forums/images/graemlins/ooo.gif
   / Valve leak down #4
   / Valve leak down #5
J.J. On my tank it says use only 5W30 motor oil. I am planning to change over to 10W40. Do you think that will slow the valve leak down somewhat, along with giving added wheel motor torque? Will this increase the chance of hydraulic pressure prematurely blowing a hose over time? What say you? /forums/images/graemlins/ooo.gif
   / Valve leak down #6
   / Valve leak down #7
JJ--could it be leaking in the cylinders, rather than the valves, that causes this?
   / Valve leak down #8
   / Valve leak down #9
Barry,
I'm not sure about the 180s, but PT now recommends 10W40, not 10W30. My tractor's label says one thing, my owners manual says the other...
/forums/images/graemlins/grin.gif Live a little -- take chances -- put 15W50 or 20W50 synthetic in it. You'll be glad you did! /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif
   / Valve leak down #10
Barry,
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2008 Ford F-250 4x4 Pickup Truck (A50323)
2008 Ford F-250...
Cat 66" Skidloader Bucket (A50774)
Cat 66" Skidloader...
40' CONTAINER (A51244)
2015 Nissan Pathfinder SUV (A50324)
2015 Nissan...
Hydraulic Power Unit S/A Towable Pump (A50322)
Hydraulic Power...
