valve leaking maybe bad springs
   / valve leaking maybe bad springs #11
DieselPower said:
You can not test valve springs by measuring free length. They need to be tested on a valve spring test stand that measures spring resistance at the compressed height.
Exactly!
I must be missing something here...I've done a few Yanmar heads and have never encountered weak springs. I can compress the valve assembly and spring with the palm of my hand after they're assembled. There isn't a radical, or high lift cam, nor high RPM's to cause valve float. Even bent push rods would have the opposite effect of allowing valves to stay open...seems to be one of a few choices. Cracked head/seat, porosity on valve face or seat or a poor grind match between valve faces and seats. All of which would fail a liquid leak through test.
I guess I'm not understanding what's happening.
THE ROOTSTER STUMP & ROOT PICKER (A51243)
THE ROOTSTER STUMP...
Lightweight 5' Pipe Gate (A50515)
Lightweight 5'...
5 Shank Inline Ripper (A50514)
5 Shank Inline...
2018 TAKEUCHI TB210R EXCAVATOR (A51242)
2018 TAKEUCHI...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
