Vibration in Ford 600?
   / Vibration in Ford 600? #1
arrows
VA
N/A
I went to go check out a Ford 600 series today to see if I want to buy it, and when I cranked up the throttle, even just part of the way, it made a loud rattle and lots of vibration. Is that normal, or a problem? It also made some blue smoke from the exhaust for a few minutes, which dissipated after the engine warmed up.
From what I could tell, the rest of the tractor looked ok, but I'm not experienced at all in checking out old tractors.
   / Vibration in Ford 600? #2
hard to tell on a rattle might be the hood sheet metal or fenders. Rattle from the engine usually ain't good
   / Vibration in Ford 600? #3
Often those tractors will have a hood vibe but blue smoke from the engine will likely call for an overhaul. Ed
   / Vibration in Ford 600? #4
a vibration from the engine could be a missing cyl. a good vibe will cause sheetmetal to rattle.
smoke on throttleup is usually umbrella seals. at minor to low-moderate levels, it is merely an annoyance, and higher levels, it can make her smoke so bad it's difficult to use her and keep plugs cleaned, and see thru the clouds of smoke.
   / Vibration in Ford 600? #5
The hoods on mine rattled so bad that it would hurt my ears after an extended time at pto rpm. I put new rubber bumpers under the hood and it is as quiet as a mouse. If you can feel the vibration, then you'd problaby want to look at a different tractor (unless you are looking for a project.)
NEW HOLLAND BR780 HAY BALER (A51243)
NEW HOLLAND BR780...
2018 FORD F-150 (A52472)
2018 FORD F-150...
BULLDOZER ROOT RAKE (A51243)
BULLDOZER ROOT...
2000 Lull Highlander 1044C-54 Series II 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2000 Lull...
1995 FLEETWOOD BOUNDER S/A MOTORHOME (A51243)
1995 FLEETWOOD...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
