RickB
Super Star Member
- Joined
- Sep 18, 2000
- Messages
- 15,190
- Location
- Up the road from Dollar General WNC
- Tractor
- Just a Scag
What square baler did you buy?
My 200HP Massey would pull the 4910 on flat, gently sloping no problem. The future plan is to put the square baler on the hilly ground instead of the round baler for obvious reasons. The 7444 will need a bigger puller.I hope you have a bigger horse in the shed than what's in your profile.
That's what I was getting at.The 7444 will need a bigger puller.
I make a few thousand small bales with a buddy of mine (I big bale his native grasslands and we small square his Timothy). I think he sold 800 of the 2000 we made last year. Its dying off a little more each year.Getting ready to put my 575 on Tractor House. Have not used it in 5 years. Sitting in the barn ready to go but no square bale customers.
If that was directed to me, I don't need a bigger tractor to run a small square bailer, in fact, I could use a much smaller tractor to run ANY small square bailer. Square bailers depend on flywheel inertia to run, not PTO horsepower. The only disadvantage to running a square bailer with a light tractor is the inertia of the reciprocating ram tends to toss you around a bit when turning at the end of a windrow. One reason why I like running small squares (only reason actually) is unlike making round bales, you don't need to run the pto at rated speed, any speed that gives you the number of slices per bale works just fine. In fact, I use my 1000 rpm pto setting with a 21-6 spline adapter and run the 1000 rpm at 640 which is reduced rpm and makes it real easy on fuel. The tractor is loafing along at about 1/2 the 640 rated rpm when I have the 6 spline stub in the housing. Just about the rpm I need to keep the ac working efficiently.I hope you have a bigger horse in the shed than what's in your profile.
It wasn't directed at you and I wasn't referring to running a small square baler. I try not to read or react to anything you post and I sure don't need schooling on small square balers. I spent half my life running them and much of the other half keeping them running properly for others.If that was directed to me, I don't need a bigger tractor to run a small square bailer, in fact, I could use a much smaller tractor to run ANY small square bailer. Square bailers depend on flywheel inertia to run, not PTO horsepower. The only disadvantage to running a square bailer with a light tractor is the inertia of the reciprocating ram tends to toss you around a bit when turning at the end of a windrow. One reason why I like running small squares (only reason actually) is unlike making round bales, you don't need to run the pto at rated speed, any speed that gives you the number of slices per bale works just fine. In fact, I use my 1000 rpm pto setting with a 21-6 spline adapter and run the 1000 rpm at 640 which is reduced rpm and makes it real easy on fuel. The tractor is loafing along at about 1/2 the 640 rated rpm when I have the 6 spline stub in the housing. Just about the rpm I need to keep the ac working efficiently.
