Victim gets even
   / Victim gets even #51
I know a guy who's teenage son hit a mailbox with a small car. The mailbox was mounted on some sort of large crankshaft and was undamaged, I guess the car was pretty badly damaged. Luckily I haven't had a mailbox problem in the 4 years I have been here, but I keep that in mind in case I ever do.
   / Victim gets even #52
Not a mailbox, but suits the title.
Buddy of mine owns a good sized independent garage. Car came in, crank, no start.
I dropped by the shop, late day, to hear my buddy on the phone, explaining the repair to the owner.
Gas tank was full of a huge amount of water. No comment from the car owner, but my buddy knows many of his customers really well, and is a good judge of people. The owner of the car works construction.
Best guess - "work" gas cans for small engines were getting emptied way too fast, for the amount of small engine operating hours. So..... trusted employees were let know which "gas" can had been mostly filled with water.
Boss sits back and watches who has no-start car trouble.
Told this one to a buddy of mine in BC, who keeps having gas stolen from cans on his property - he's going to have some fun. I suggested that he mix salt in with the water.
:D
Best rural box setup I've seen was a big "Skyhook" type (high inverted "L", with the post set way back from the road). Standard box was suspended from long free hanging chains - it just swung freely if hit.
Rgds, D.
   / Victim gets even #53
Rgds, D.
Yes, this is effective especially in the snow belt where plows can hit it. Otherwise, build a pillar out of stone and concrete or brick and encase the mailbox and paper slot in it. Make sure make it 24-30" deep.
We use granite here - 7' long 8x10" about 800 lbs 36" below ground and a HD box lagged to the granite.
   / Victim gets even #54
Yep, I'm in snow plow country. Though we don't get the same snow amounts that we used to, back when - as a kid I remember rural highways with drifts that were way taller than the big highway plow trucks. But, we still have plenty of plow trucks running around, and many of those drivers are too busy texting, or ?????
I like to have things over-built, so I like how you think Carl !
What I find ironic about the descriptions listed here of counties, transport authorities..... ordering rural property owners to take down solid mounts is that many of these same jurisdictions probably have many, many miles of the old "cheese-cutter" road side barriers (cedar post and steel wire). IMO, at speed, the "cheese-cutters" are way more lethal to people in small cars than the occasional sturdy post. :thumbdown:
Rgds, D.
   / Victim gets even #55
Rgds, D.
It can be argued that most roadside barriers are usually further away from the centerline than a mailbox post and therefore a vehicle is less likely to impact one. Hmm, have never seen the "cheese-cutter" term before, I cannot recall the last time I saw one but I recall what they look like.
   / Victim gets even #56
My mailbox is made of plastic; it's only been hit once, and judging from the marks, may have been a T-post, or maybe part of one. The plastic is very resilent, no harm done.
   / Victim gets even #57
The big problem around here JD is icy roads, something I'm sure you're familiar with in Michigan. Most people will slow down (sometimes because they have no choice) for 12" of snow, but many won't for an icy road.
Add to that, constricting road maintenance budgets - unless they are trying to deliberately run down the budget at the end of the season, many areas won't roll trucks for less than a certain minimum amount of snow.
At the high velocities many people drive on rural roads, at least around here, these post and wire barriers get hit often. One winter, I was talking about this with the Fire Chief at the next town south of me. Pretty well every post and wire barrier was smashed up pretty well, between my town and his. The difference in setback here between a mailbox and these barriers probably ranges from 3' to probably 10' max. At speed, on ice, often people don't get stopped in the extra few feet - many of these vehicles end up hundreds of feet beyond the barrier, they are going that fast.
I bring this up, because it is a significant safety issue. I picked up the term "cheesecutter" from a civil engineer I was talking to - many people have seen how a wire cheesecutter works, these cedar post barriers work pretty much the same. This engineer related having to explain a picture to new crews who were being trained on dealing with accident scenes "No, those aren't sacks of potatoes in that wrecked car". They keep burlap bags in the road service trucks, to put over the torsos after the roof pillars get sliced off by the wire barriers. As I've posted before, most anybody over 3' tall gets decapitated.
These post and wire barriers were designed way back - cars then were tall (compared to todays cars), mounted on heavy frames. The wire barrier was mostly intended to align with and stop the frame on old cars. Today's cars, being low and aerodynamic, can often go under and through the wire if they are going fast enough.
The civil engineer I was talking to worked in Toronto. Years ago, they even had these post/wire barriers around the city. They have mostly all been replaced in Toronto with more modern barriers today.
The problem in most of Canada (big country, not many people), and parts of the USA, just comes down to $$$, as with most things. We have many many thousands of miles of roads with these old style barriers in place, to replace them all at once is not in the cards.
In a given county, what they usually try and do is upgrade the barriers that get crashed into the most, first. That road south of me has a long steep valley, that often ices up badly, esp. at 4:30am - some of those barriers finally got upgraded over the last 2 years.
I should apologize for somewhat drifting this thread, as you probably won't get too far trying to argue with your local county about the safety of these post/wire barriers. Typically, driven by their legal counsel, the standard line is "There is nothing wrong with these barriers". Until you talk with somebody inside the "road" industry, you usually won't get the real story.
People moving out to, or traveling through, the country often don't understand this legacy road hazard.
If you live in the flatlands, and drive on straight roads with no ice conditions, you are lucky in this respect.
Rgds, D.
   / Victim gets even #60
John Deere 1025R (A53317)
John Deere 1025R...
AUCTION STARTS HERE @ 9AM (A52709)
AUCTION STARTS...
2013 Ford F-550 Ambulance (A56858)
2013 Ford F-550...
2019 Dodge Charger (A56859)
2019 Dodge Charger...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
Utility Tilt Trailer (A55787)
Utility Tilt...
