Vintage Ford tractor mods, hacks, upgrades, add-ons, accessories, customization
   / Vintage Ford tractor mods, hacks, upgrades, add-ons, accessories, customization #1
Santa Craig Cringle
Lawrence County, AL
Current - 2021 Kioti CX2510, Previous - 1959 Ford 881
I just got my tractor and I've been perusing this forum, others, and google for a few days now looking for cool mods, upgrades, etc. that people might have done on some of these 40-70 yo tractors, and surprisingly, I've come up nearly empty-handed save for a couple things like a 12V upgrade. However, I find a plethora of things that were done on Kubotas, JDs, and a few MFs.
Am I missing something? Literally nothing out there for my 881.
I'm interested in LED lights & ROPs for start, but really anything on an old Ford that can get my creative juices flowing.
   / Vintage Ford tractor mods, hacks, upgrades, add-ons, accessories, customization #2
I'm not sure what your edging for.
an 881 is a late model, prior model ford.
Most of the older fords had less options.. the 881 is fairly option encrusted usually.
You have a multi speed independent pto. You have the option to adda 400$/800$ single or dual spool hyd valve onto your hyd top cover, if it does not have one already. You ( IIRC ) have power steering.
You CAN get rops. same rops fits 1939 9n thru 1975 tractors the size of the 3000 and down.
Lampa are lamps.. add at will .. any kind you want.
You already covered the alternator modification.
about the only other options left some people did was add an idler wheel and rear track kit ( aarps or bombardier ).. or an elenco 4wd conversion.. which on an SOS I bet is pretty rare and spendy.
in other words.. you bought a model that was pretty much the premium full upgrade of the line available at that time.
   / Vintage Ford tractor mods, hacks, upgrades, add-ons, accessories, customization #3
Generally, I am against 12 volt conversions on tractors that left the factory at 6 volt. Usually folks do that, to make starting easier, as their engine begins to show excessive wear and corresponding compression loss. If I am buying a used tractor, especially when it is cold outside, if it is 6 volts, and still starts good, I don't need to go much further to know that I am getting an engine that still has a lot of life left in it. Not so after it is converted to 12 volts. I usually just "walk away" from those, as it ain't too difficult to find good, used, 6 volt tractors. Also, that 6-12 conversion significantly drops the collector value of rarer models, such as the old Ford trikes, that Soundguy is fond of.
There are probably more folks out there who prefer 12 volt converted tractors over original 6-volters, but I just ain't one of them, for the reasons I gave above. My 1951 Ford 8n still starts good, even when the temp drops below zero, on 6 volts. I do admit that, even for me, the old, stubburn, Dutchman that I am, there are some exceptions to this. I run one tractor, that came from the factory at 6 volts, And I converted and now use at 12 volts (10 hp, Farmall Cub). Much of that tractor's duty consists of operating a 12 volt, 15 gal. sprayer. I use that on my apple orchard, gardens, and to put Roundup on field corn (while cultivating). I don't think them little sprayer pumps are even available in 6 volt, and if they were, they would definitely cost more and be harder to find parts for.
For snowplowing in the winter,that little tractor does start real good on 12 volts, never needing any either no mater how far below zero the temperature drops. What was your reason for converting to 12 volts?
As far as other options, all I can think of, that Soundguy left out, Are: First, a stabilizer link kit for the 3 pt lower link arms. I used the same one (From TSC) on both a 1951 Ford 8n, and a 1970 something Ford 2000 diesel, so it should also fit your model. That will save your lower links when using something like a pond scoop in the reverse position. Lower links were designed for the tractor going forward, not reverse, and they don't hold up very well for that. The addition of the stabilizer link kit will completely protect them lower links.
Second, I like to fabricate a little bracket, and hang a hammer on the back of a fender, to ease in implement mount/dismount, shear-pin removal, etc..
Third, on my bush-hog tractor, I fabricated a canopy that works better than any commercial model I have used, including them big fiberglass ones you often see on Fords. I made mine a little bigger yet, and deeper, so it blocks the sun better. I also minimized weight by using a canvas (old, brown-duck boat cover), over wood (2x2 pine) frame construction, and a couple small steel support rod construction. It connects to the roll bar and frame with (4) bolts, and is so light that I can lift it with one arm, and have it on or off in just over a minute. It has also held up well for 10 seasons now. I sometimes get in fights on this site over this, but I much prefer that canopy, on hot, sunny day, over an air-conditioned cab. The cool breeze I get in that open-station, while completely protected from the suns punishing rays beats out them cabs hands down on smaller tractors. In more than 40 years of running open-station tractors, I am still waiting for my first bee sting.
Good luck with you Ford. I hope it gives you many years of great service, as has every Ford I ever owned.
   / Vintage Ford tractor mods, hacks, upgrades, add-ons, accessories, customization #4
Pretty much got the fully loaded caddy in a late 50's tractor.
Kirk
   / Vintage Ford tractor mods, hacks, upgrades, add-ons, accessories, customization #5
I will pretty much agree with you on the 12v verses 6v argument. All the tractors I have had over the years not one has been converted to 12 volts. If they won't start on 6v then something needs attention. My 850 has been on this place for 8 years now and still has the original battery in it. It was getting hard to start so it was given a tune up and now starts like a champ. No engine heater on this one. I don't think I have ever had a 6v tractor that was hard to start if it was kept within specs.
The Dexta came with two 6v batteries hooked in series and as soon as those batteries go bad I am going to convert it to one large 12 volt. Two batteries and their associated cables are just more places for corrosion and other problems to pop up.
   / Vintage Ford tractor mods, hacks, upgrades, add-ons, accessories, customization #6
i agree. and there are plenty of good 12v alternatives now too.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2017 Nissan Sentra Sedan (A55758)
2017 Nissan Sentra...
20'x30' All-Steel Carport W/ Enclosed Sidewalls (A47477)
20'x30' All-Steel...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
ATTENTION PLEASE READ (A53314)
ATTENTION PLEASE...
Always 5  O' Clock Somewhere Sign (A53316)
Always 5 O' Clock...
