Shimon
Platinum Member
Well, I plan on getting either a Voltmaster or NorthStar 12kW PTO genset in the next week or two and I was planning on installing it inside my shop in the corner on a platform and make a small sliding door in the side of the shop to put the PTO shaft through. I plan on backing up the tractor to the shop whenever I need to run the genset and I would just need to hook up the PTO shaft and go. The electrics will be hardwired to a transfer switch.
I would like to mount a volt and freq meter on the outside of the shop just above the PTO shaft opening in the side of the shop so that way I can set the tractor RPM while watching the meters. I'm debating between a volt and freq analog gauge or this Blue Seas marine digital "multimeter" gauge. The nice thing about the digital gauge is that it would be easier to read in the dark and it has volts/freq/amps/watts but the downside is you can only see one parameter at a time. Although I would guess that the only parameter I would care about while setting the throttle would be freq. I plan on mounting the gauges in the box with a locking lid so they don't walk off when not in use.
Anyway, my question is...does anyone know of a pre-made panel that already has ANALOG gauges mounted in it that has a lid and is lockable and is rain proof? I searched on the net but couldn't find anything. I guess I can modify an existing panel and mount the gauges in something like this. Any suggestions appreciated.
