W R Long electric hydraulic Valve set up
   / W R Long electric hydraulic Valve set up #1
keyman1808
Platinum Member
Freetown, MA
BX24
I was wondering if anyone has used this setup. I have spoken with the mechanic who works on my BX24 and he thought that these types of valves use too much power and would strain my electrical system. Anyone have any thoughts on this. Also anyone recomend were to pick up on of these W R Long kits. I call the 2 listed dealer here in MA and got no answer about pricing.
   / W R Long electric hydraulic Valve set up #2
I have been doing a lot of reading about the Long Electric over hydraulic valve as I will be purchasing one, and can find nothing that suggests that it draws anything but a small amount of electricity. It is not a motor driven hydraulic pump/valve (which would draw significant current) but an electric switch controlled valve that gets it's hydraulic power from your tractor's hydraulic system. I do not believe your electrical system will even notice it is there.
Do a TBN search for WR Long and you will get a great deal of information about these valves. The only issue I have been able to find about these valves is that they are a bit pricey...otherwise only good things.
Jim from NH
   / W R Long electric hydraulic Valve set up #3
Think my valve is wired into a circuit with I think a 15 amp fuse, you use it for short time only, nothing more than 5 seconds to close grapple all the way.
David Kb7uns
   / W R Long electric hydraulic Valve set up #4
There are LOTS of people with them-a simple search of the site will show you that.
And your mechanic does not know what he is talking about...
Call Nelson at WR Long-he will tell you what dealer in your area can order the valve kit for you.
   / W R Long electric hydraulic Valve set up #5
Plus, your BX24 has the 40 amp alternator standard, so you have plenty of power anyway, not that you'd need it for this application.
Thanks for all the help. I will call W R Long and see if I can find someone that will ship to me seeing my locals are not very helpful
   / W R Long electric hydraulic Valve set up #7
Kennyd said it right - your manic does not have a clue - you will be fine.
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A55788)
2006 International...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
Wacker Neuson DT08 (A53314)
Wacker Neuson DT08...
