walmart and HF penetrating oil
   / walmart and HF penetrating oil #21
If you mill or tap aluminum, try A9. Works great.
Do alot of aluminum. Havent heard of A9? who makes it?
I am generally limited to what they decide to order at work. And they order alot so I have a big selection.
Crown butter-cut in the quart can
Liquid wrench in the quart can
and the following in spray cans:
chesterton 395
crown all 4
CRC cutting and taping oil (real foamy and sticky) which I like for tapping
Tap tool
aero kroil
Generally, I grab the tap tool or crown all 4 when doing aluminum. Both are light weight and thin kinda like wd40. The CRC is great for tapping cause it is real tacky.
When milling or turning aluminum, I usually use coolant oil. Mister on the mill and flood cooling on the lathe.
is your flood cooling a water/oil emulsion?
   / walmart and HF penetrating oil #23
Yeap. We use that in the mister too.
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2006 International 7400 Dump Truck (A47477)
2006 International...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
