Want a tie down fastener for trailer to go between deck boards
   / Want a tie down fastener for trailer to go between deck boards #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
I've a trailer with deck boards that shrunk over it's life such that there are cracks between boards that easily fit a 3 gauge corner angle bracket.
The trailer is used as a flatbed for hauling tractors.
as a trailer w/ sides for hauling miscellaneous stuff,
and with a homebuilt 4' high cargo "box" w/o floor other than the trailer decking for transporting.
With the box on I've places above the floor to attach straps to but I'm transporting some heavy equipment like a plow and a 5' tillerwhich I'd like to anchor to the deck.
So I want the design easily removable.
The picture shows one such bracket dropped thru a crack.
I'm looking for an elegant solution on putting a "thick as I can" (3 or 4 gauge) piece of metal thru the "slot" and fastening it so it doesn't pull thru.
Presently I'm thinking of dropping the angle bracket thru the crack and then put a bolt w/ nut thru the bottom hole that sticks under the bed, then a bolt w/nut thru the second hole up. I can then fasten something to the remaining portion of the angle bracket sticking above the deck.
I've thought of just a straight piece of steel strapping, but have the angle brackets.
So TBN, any more elegant solutions?
   / Want a tie down fastener for trailer to go between deck boards #2
To install a tie down on a wood deck you need to use a backing plate on the bottom of the wood. Preferably close to a steel cross member. Just an L bracket through the gap in the wood is not a secure way to tie down. If you don't want to drill a hole for recessed tie downs you can use the surface mount D-ring type but still need a backer plate on the bottom. These are available from Etrailer and most trailer stores.
   / Want a tie down fastener for trailer to go between deck boards #3
Anything that fastens to wood and may have lots of sudden stress makes me nervous.
For light and medium duty, I would make 1/4 inch steel cable loops through the crack and around a steel crossmember. If you put the clamps underneath, the cable will drop out of the way in the cracks when not being used. You could do the same with a U-bolt left loose.
Bruce
   / Want a tie down fastener for trailer to go between deck boards #4
If i was going to use anything, it would be attached to the metal and not the wood. I think some stake pockets added along the outside of the frame would come in very handy and give you something to attach straps to. You can use the pocket tie down above in the middle pic. Route the wood to accept a flush mount, and locate it over one of the cross members for secure support.
   / Want a tie down fastener for trailer to go between deck boards #5
Deck boards are causally attached to the cross members of the trailer with self drilling TEK screws, I wouldn't put to much faith in them holding-or the boards may easily pull up over the screw heads especially since the boards have shrunk.
   / Want a tie down fastener for trailer to go between deck boards #7
jumping on the band wagon as well. not the best idea to attach directly to the wood flooring for tie downs
you have a metal frame " use it " attach hooks (drill frame or weld to frame)
you did well on the sides, but i think ya over stepping limits on the tie downs via wood flooring.
   / Want a tie down fastener for trailer to go between deck boards #8
I've been thinking about the same problem (tiedowns that ar accessible in the middle thru the gap between (shrunken) floorboards. George I was looking at the same recessed rings, but was thinking to put 2 of the bolts thru the steel crossmember.
   / Want a tie down fastener for trailer to go between deck boards #9
Yes, as mentioned, wood floor itself is not a good thing to install a tie down to. Tie downs need to be attached to the frame in some way whether you go through the wood and bolt to a cross member or directly to the side rail frame.
   / Want a tie down fastener for trailer to go between deck boards #10
George I bet you moved back because of the "other" metal flange on top. A reasonable way to make your tiedowns very very strong is to add a plate on the bottom (with 4 holes). Drill 2 more holes ahead and add bolts that go thru the steel flange(s?). Use Self-locking nuts so its secure without having to squeeze down hard on the upper flange. Even a thin plate like 10ga, or 1/8" is very strong in this application.
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A53421)
2006 Magnum 125...
2005 Chrysler Town and Country Limited Van (A55853)
2005 Chrysler Town...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
POLARIS RANGER 570 RTV (A51406)
POLARIS RANGER 570...
30007 (A53424)
30007 (A53424)
