want to build a hammer mill?
   / want to build a hammer mill? #1
pickstock
does anyone have any plans for a small scale hammer mill?
i have a little idea that im going to make when i get time but does anyone have plans or drawings?
   / want to build a hammer mill? #2
Is this for grinding feed?
Going to be a stationary unit or portable?
Roy
   / want to build a hammer mill? #3
homemade hammer mill plans - Google Search
some of the garden shredders are basally hammer mills,
IMO I would find one that was manufactured and copy it, my be not as wide as the full farm mill, (my old JD mill is 14 inches wide) and they made a few smaller sizes I think as well, bear cat made a heavy one,
and of course there are many others, but if you have a friend who has one take pictures and a tape measure and copy,
you can down load a parts book of the old JD mills off of the john Deere parts site, (you will have to sign in to it),
https://jdparts.deere.com/servlet/c....enrollmentcontroller.DealershipListSelection
not sure if this URL will work but if it does the 14 hammer mill parts book, in pdf,
http://jdpc.deere.com/jdpc/JDPC/attachments.jsp?associatedPc=PC0682.PDF
this one was slow in opening, for me,
http://jdpc.deere.com/jdpc/pdfs/PC0429.PDF
there is a post on this discussion on RPM of the rotors,
http://www.homesteadingtoday.com/archive/index.php/t-169030.html
(one does not need a blower unless that is your method of wanting to move the ground materials, but one can jsut let it drop out of the bottom)
also do a image search,
http://www.google.com/search?q=hamm...RI_Pr0QHdxazVBQ&ved=0CFUQsAQ&biw=1148&bih=663
hey bhd cheers for that info
oldnslo(?) its mostly going to be for making rock dust but i will possibly use it for feed when my operation becomes big enough
   / want to build a hammer mill? #5
Rock Dust? Does that mean you are making a rock crusher/pulverizer? A hammermill for grinding feed Vs a rock crusher are two entirely different machines.
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
207274 (A52708)
207274 (A52708)
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
KOMATSU WA270 (A58214)
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
