Want to convert surge to electric, what do I need?
   / Want to convert surge to electric, what do I need? #1
mjw357
Platinum Member
The Sticks, Ohio
Kubota B3200
20' Ridgeline cargo trailer, has 12"x2" drums with 6 x 5-1/4" bolt pattern. Drums have Dexter on the outside, look to be in good shape. How do I know what electric brake kits will fit? As far as bolting the new backing plates up to the axles?
The builders plate is just a sticker really, and looks like they just wrote all the data in there with a pen and it's almost impossible to read. So I don't know what the axle rating or GVWR is on this trailer.
When I do this, should I be doing all 4 wheels or is just one axle OK? This is non-commercial use, we mainly haul hay short distances with it.
edit: just found this: Ridgeline Trailers, Washburn, TN
   / Want to convert surge to electric, what do I need? #2
I'd do all four .... When you buy new electric brakes they come complete for left and right side using your same drums. You'll need a Brake Controller, a Break Away Kit, probably new truck and trailer 7 pole connectors, about 35-40 feet of Duo 10 gauge wire, some butt connectors, zip ties, 3M tape and probably want to repack the bearings with new seals. You'll need to immobilze the surge slack in the tongue by welding or some other means etc. Look to your trailer manufacturer for some advice and/or also go "www.etrailer.com" for videos and parts... or maybe to www.randpccarriages.com for good info. This just a few things that come to my mind.
Cheers,
Mike
   / Want to convert surge to electric, what do I need? #3
You need to do all 4 wheels. You have 6 lug wheels so 12" brakes are what you need. They are used on 6 lug trailer axles which are 5200# or 6000# axles.
You will need to replace the coupler on the trailer also or weld your surge coupler to immobilize it.
I second R&P Carriage. I get all the stuff I need from the to service the fleet of trailers I maintain. They have full kits to do what you want to do.
Chris
I bought it used, a previous owner already welded it all up.
   / Want to convert surge to electric, what do I need? #5
Forgot to mention....you'll also need about $300-$400 dollars.:cool:
Year: 2006 Make: Ford Model: Ranger Vehicle Type: Pickup Truck Mileage: 86,950 Plate: Body Type: 4 (A55788)
Year: 2006 Make...
2023 54' Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54' Hooklift...
2014 CATERPILLAR 305E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
UNUSED FUTURE FT-13 EXCAVATOR (A54756)
UNUSED FUTURE...
UNUSED IRANCH 16" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 16"...
