wanted:PTO-to-shaft drive attachment
   / wanted:PTO-to-shaft drive attachment #11
Works fine from my computer
   / wanted:PTO-to-shaft drive attachment #12
and pic # 2
   / wanted:PTO-to-shaft drive attachment #13
I t is Model D101
   / wanted:PTO-to-shaft drive attachment #14
3741 Publishers Drive
P.O. Box 6939
Rockford, IL 61125-6939
815-874-8110 voice
815-874-8833 fax
info@rjlink.com
Does this help?
Ron
The unit in the picture might work. I was thinking that the various pumps would be mounted on some kind of steel plate between the swiing arms. This wold be driven by a PTO shaft w/U-joints. I think it would be a lot better to have that PTO shaft turning at 540 RPM and not 3600!
Which implys that this gearbox in the pic would be mounted on the plate somehow.
Hmmm, I think its time for a sketch. (see attached)
My pump applications (air compressor, pressure washer, etc..) are of such modest HP (< 10HP), I'd think the tractor could run at moderate RPM all day, and not even know they are back there.
   / wanted:PTO-to-shaft drive attachment #16
Looks like you have about 30 hp tractor. Now to make the 6-1 conversion work, you will need to run that tractor at pto speed, near wide open. No throttling back as you say, as your tasks are speed dependent.
So, you will be using fuel for 30 hp to run your 5-10 hp items.
Another way to go is run the tractor at idle, and compensate for that with a bigger gear ratio. The problem there is the impulse to run 'just a little faster' and wreck all your implements.
For your applications, a cheap belt setup will work, rather than the $$$ gearsets.
Still not sure it is worth it, use more fuel, more noise, less manuverable, and have to bolt/ unbolt for the different operations.
--->Paul
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
1271 (A50490)
1271 (A50490)
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2019 FREIGHTLINER M2 106 REFRIGERATED TRUCK (A52706)
2019 FREIGHTLINER...
SHOP MADE MANIFOLD TRAILER (A53843)
SHOP MADE MANIFOLD...
