Wasps in the attic
   / Wasps in the attic #21
Or you could raise a flock of seagulls up there but then you'd have to deal with bird poop.
   / Wasps in the attic #23
I use regular household ammonia. If you use a pump up sprayer; spray the nest after dark. (They are all home). I like to use my propane fogger. I just sub some ammonia. Looks like your house is on fire; but they will leave.
   / Wasps in the attic #24
I have regular wasps, yellow-jackets & bald-faced wasps. I eliminate those that build nests right in the entry way to the house. So far - 34+ years - none have found a way in to build nests in the house. About 25 years ago I noticed ants trudging along the exposed beams in the house. Tracing back to the source - I found a LARGE ant nest in the small attic I have. Threw two ant bombs in the space - we went to visit my son, in town, for the day. Came back - aired out the house and cleaned out the ant nest with my big shop vac.
Diazinon granulas applied liberally around the foundation annually has solved this problem and the ants now stay where they should be. I still check the attic space at least two time a year.
2015 VOLVO L90H WHEEL LOADER (A52705)
2015 VOLVO L90H...
2004 FREIGHTLINER COLUMBIA (A53843)
2004 FREIGHTLINER...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
2021 CASE 580SN WT (A47477)
2021 CASE 580SN WT...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
