waste oil heater
   / waste oil heater #11
</font><font color="blue" class="small">( I read somewhere that Wal-Mart is putting in two stores that will be using used motor oil & cooking oil to heat the stores. )</font>
<font color="red"> ~~~~~~~~~~~ </font>
My next door neighbor A diesel mechanic was telling me that the shop where he works is heated with used oil.
Said they have A couple of storage rooms full of 55 gallon drums of the stuff.
<font color="red"> </font> z
   / waste oil heater #12
cj7,
A TBNer built a waste oil burner year(s) ago. Might want to search under the Project discussion area. It was a long thead and he had lots of pictures.
Later,
Dan
   / waste oil heater #13
Back in the late 70's I worked at a place where we used crankcase oil to heat the shop in the winter. We mixed diesel in it and lit it with a cutting torch /forums/images/graemlins/blush.gif. I would go home and blow black soot out of my nose every night--the thing wasn't vented to the outside. /forums/images/graemlins/frown.gif Anyhow, it stinks to boot. /forums/images/graemlins/tongue.gif
   / waste oil heater #14
Thats pretty bad....I'm amazed at what some people do. Your lucky your not dead.
Once you have one a burning a few minutes there should be no smoke. If it smokes you have to much oil, not enough air or a bad burner design. Shouldn't have any smell either.
   / waste oil heater #15
Or was it just a bucket of oil. That sucker would smoke nomatter what you did.
   / waste oil heater #16
I don't know where the guy I worked for got the thing--it had
provision for adjusting air flow. He knew how to stretch a buck a mile long. Anyway, he propelled me to get off my rear end and go on to better things! /forums/images/graemlins/smile.gif I wouldn't own a brand new JD 5302 now if I had stayed there breathing that smoke and working for scraps. Probably right, would have been dead meat. /forums/images/graemlins/frown.gif
   / waste oil heater
thanks guys for the coments
yes I did search and found the old thread.
I think I am not going to build one.
Looking at a Potbelly stove
or WASTE OIL ELIMMINATOR from Northern. But I can not find much info that what Northern tells you.
KJ (5) Rolls of Galvanized Welded Wire Mesh (A50121)
KJ (5) Rolls of...
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2017 John Deere TX Gator Utility Cart (A51691)
2017 John Deere TX...
2012 Cat 272C Skidloader (RIDE AND DRIVE) (A50774)
2012 Cat 272C...
CFG Industrial MX12RX (A50121)
CFG Industrial...
