stuartshomepc
Bronze Member
Well, I'll chime in again with a useful post this time...
So how does that all mesh with using it on a vehicle...
The hypothesis is that a car's alternator is constantly producing power that is not being used by anything. By pumping that power to an electrolytic cell it can be used to separate water into hydrogen and oxygen which is then fed into your intake and burned by the engine.
The place where the hypothesis falls apart is the "unused power" being produced by the alternator. Anyone familiar with power generation knows that when you put a load across a generator the motor driving the generator has to work harder to spin the generator at the same speed. This is just as true of a car's alternator. Every test I've seen shows the electrolytic cell pulling in excess of 20 amps of power. That power has to come from somewhere and it's going to come from somewhere.
Finally a nice logical explanation. Most of theses "Inventors" don't tell you that the electricity is not free. Some people think that just because the alternator is spinning it has all sorts of "Excess" energy. What it has is excess unused "capacity" but once you put a load on it the thing works at about 60% efficiency of the rotating energy that went into it. And that the car's engine that is spinning it is only about 33% efficient in turning fuel into work (the rest goes out as heat the the cooling system, friction and exhaust heat). So to get 1kw of electricity out of the alternator you need about 4kw worth of fuel.
I once got into a parallel discussion with a guy by telling him that on a front wheel drive car that the back wheels were just spinning so we should just hook up electric generators to them to make a hybrid. Heck, the energy is free right? They are just going around... let's harness that. He thought that it was a brilliant idea until I tried to explain to him that the motors would cause resistance/drag that the front wheels would need to overcome to pull the car against the extra load, but he didn't get it.
Maybe I just missed it and should have put a generator on top of the car, powered via a propeller. That would not put extra load on the wheels
Yes, you can generate Hydrogen from water. But you need a lot of Hydrogen to run that engine, which takes a lot of electricity do the electrolysis to make the Hydrogen. Maybe if we put a nuclear power plant next to a lake and just lay the wires in the lake, with a funnel over the lake we can make the Hydrogen and get it for free!
