Water and antifreeze for ballast/ rear tires
   / Water and antifreeze for ballast/ rear tires #11
</font><font color="blue" class="small">( water and antifreeze...That's going to make them rust out for sure isn't )</font>
Does it make your cast-iron engine block rust out for sure? See where this is going. A/F has corrosion inhibitors. Keep up with it.. it should be good to go.
Soundguy
   / Water and antifreeze for ballast/ rear tires #12
Soundguy
   / Water and antifreeze for ballast/ rear tires #13
A small difference -- there should be no air in the engine cooling system. There is in a tire. The oxygen will bring about some amount of rusting until it's used up, regardless of the inhibitors. Ever see old coolant from a radiator? Got some in it in most cases.
On the flip side, this is a vote against having to rotate the air in your tires -- if you do that you introduce more oxygen with every air change. /forums/images/graemlins/smirk.gif
   / Water and antifreeze for ballast/ rear tires #14
   / Water and antifreeze for ballast/ rear tires #15
</font><font color="blue" class="small">( A small difference -- there should be no air in the engine cooling system. There is in a tire. The oxygen will bring about some amount of rusting until it's used up, regardless of the inhibitors. Ever see old coolant from a radiator? Got some in it in most cases.
)</font>
A properly filled tire has fluid over the top of the rim with just a small void of air above. You will have far less air in contact with the tire rim than you would with no fluid fill. Antifreeze and distilled water would be the best choice, but I don't think you'll see any problems whatsoever with the antifreeze and tap water.
   / Water and antifreeze for ballast/ rear tires #16
)</font>
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
JCB 525-60T4...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A52748)
2023 Maxx-D TDX...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52748)
NEW 2024 LOAD...
2019 FORD F-350 (A52472)
2019 FORD F-350...
2023 John Deere 8R410 MFWD Tractor (A52748)
2023 John Deere...
