Water conditioner - Re-gen with no water?
   / Water conditioner - Re-gen with no water? #11
Sorry, I really don't understand what you mean, or what you are doing.
Capacity is based on salt dosage. With 15 lbs/cuft of regular mesh resin you get 30k of capacity. Fine mesh will be 20+/-% higher; SST-60 about 30%.
What resin are you using; fine mesh, regular SST-60?
52k out of 48K, how's that? What volume of resin in cuft do you use in that softener? And what is the salt dose in lbs?
The actual total amount of hardness... you mean the max gpg the resin can handle? Most resin is capable of removing up to 100 grains per gallon. That isn't part of this problem of running the service run longer than normal and then regenerating with the same salt dose.
Gary Slusser
   / Water conditioner - Re-gen with no water? #12
we use a non uniform fine mesh.
In other words, the resin bead is not a uniform size.
This allows us to have a greater surface area for ion exhchange to take place in the same volume of space.
I guess an analogy would be, if you filled a room with beach balls, you would have a certain amount of surface area.
If you filled it with beach balls, basketballs, baseballs, golf balls and BB, you have the same volume of space with more surface area.
Our systems typically range from half a cubic foot of resin up to 3 cubic feet. (that would be a really high capacity system.)
We also use proportional brining, which means we are not using the standard 12 to 15 lbs of salt to recapture a typical cubic foot of resin's hardness. We've found that sodium exchange efficiency is greater with multiple smaller regens than one massive. Also less chance of channeling and hard water leakage, as the bed is fluffed more often.
I don't endorse my company's brand on the site, but if you'd like to discuss it in person, feel free to send me a private message and I'll call. It's always interesting to see what other manufacturers are doing and to keep up with the competition.
/forums/images/graemlins/grin.gif
anthony
   / Water conditioner - Re-gen with no water? #13
It sounds as if you are mixing resins or using Purolite's C-100e; they describe it as you have - vairous sized beads, which any non-standardized resin is when compared to say Sybron's C-249 and others. BTW, I use Purolite C-100e.
Proportional brining is/was a trade mark/patented Autotrol feature in their 269/463i control valve sold as a Technetic an now an Avantapure softener. Varaible brining is the same thing without the higher efficiency of the Autotrol distributor tube, which had the patent. It has a two part distributor tube through the freeboard area in the tank. I used to be one of five dealers in the US authorized by Autotrol to build my own softener with that control and distributor - I made the distributor and did not have to buy assembled units. It was also used in the rotary design Technetic 1000 and Technetic Plus controls and the 169/463i control valve. Those units are only sold through exclusive territory dealers through about 8 OEM distributors in the US. Fleck has 2 controls with variable brining, the 6700 and 7000 and are sold to any dealer anywhere as completed units.
BUT IMO any time there are more frequent regenerations, the unit uses more water in total on an annual basis and salt efficiency is questionable while the life of the resin is also. That's due to them very likely regenerating every day or two but certainly much more often than say the once per week of a correctly sized 'regular' regenerated softener.
But you don't get 52k of capacity out of a 1.5 cuft (48k) volume of resin without the use of a fairly high salt dose if not the maximum to do so. You need to understand this a bit better than I think you do, or you're not explaining it incorrectly.
The fully regenerated capacity of a 3 cuft softener using C-100e requires 15lbs/cuft= 45 lbs to get 90k. That is 90000/45= 2000 grains/lb used, which is terrible efficiency. If you need 20k of capacity for once/week regeneration, set the control to use 20K and dose at roughly 5 lbs (total) and that gives you roughly 3600 grains/lb. The SFR of a 3 cuft softener is 20 gpm.
This missing regeneration we are discussiing is more problematical in a propotional regenerated softener than in a regular softener.
So it is still best to unplug the unit if the water is turned off when you're gone; which it should be to prevent the possibility of serious water damage problems when no one is home.
Anthony, you're welcome to email or PM me if you want to discuss the correct sizing of a softener etc.. Or do a search for "softener sizing chart" with the "" and find those that mention SFR.
Gary Slusser
   / Water conditioner - Re-gen with no water? #14
I'll pm you. We have systems on line here that have been working virtually non stop for 30 years, and that's the original resin bed. We do use carbon with the resin to reduce the chlorine, the primary culprit in the striation problems found in most resin, and I am familiar with the Sybron and Purolite as we have also used them both in the past.
I'm also familiar with the technetic, as they approached me when I owned my own company a few years ago. We tried their systems, and unfortunately, there were too many kinks. That was about 8 years ago or so and I believe they were introducing a new design. I'm sure they're better now. We installed about 40 units before giving up on it.
As for the efficiency, the amount of sodium dissolved is, of course, regulated my the amount of water dispensed. Less sodium, less water. I think we're splitting hairs here anyway, as we're talking about pennies worth of water, in either direction.
We want our systems to regen on average twice a week, not once, to avoid the channeling problems, etc. Our valve will monitor the amount of water use, and in 10% increments recapture only that which is necessary. In other words, if we have app. 37% capacity used, we'll regen at 40%. We really do not want to even approach 100 percent, because, as you stated, we would have terrible sodium/calcium exchange efficiency rates. Also, we are of course using soft water backwashing.
Our typical customers (please remember, we're talking residential systems on the average of 1 cubic foot) are using far less than one 40 lb bag of salt per month. Average dosage seems to be running between 2 and 4 lbs. Now that seems, to me, to be very efficient. FYI, in this area, the water is tyically running 8 to 10 grains.
To go back to the original question, I guess we'll just disagree on that one. /forums/images/graemlins/wink.gif
Anthony
   / Water conditioner - Re-gen with no water? #15
My sizing usually provides for less than 10 lbs per regeneration, most in the 4-8 lb range, for a once per week regeneration unless there is iron. I don't have to worry about channeling but how do you provide for proper SFR with 1 cuft softeners?
I take it your're with Kinetico or Ecowater, or you have a softener unknown to me.
Gary Slusser
Gary & Anthony,
I'm back from vacation. Left the water on (this time).
Thanks for the replies.
You guys went waaayyyy over my head in most of the posts.
The unit I have is a RainSoft. The carbon tank is on a 6 day timer, the pellet tank is the computer one. I have not seen in the manual anything about a day timer overriding the usage.
So.... For this unit/manufacturer, can I turn off the water and let them go through their cycles without water?
Brian
   / Water conditioner - Re-gen with no water? #17
Welcome back and I hope the vacation went well.
If a metered control valve, it won't regenerate unless you have calendar override set. But IMO you shouldn't go away and let the water in in any house.
With a mechanical or electronic day timer, which your RainSoft softener may very well be, they regenerate/backwash based on how many days since the last one so if it regenerates, or the carbon filter tries backwashing, with no water, and you come home say 3 days later, there would be 3 days left before it regenerates/backwashes if you don't do a manual regeneration/backwash. That means it/they is/are 3 days past when it/they should have regenerated/backwashed and you'll more than likely run out of soft water before the softener regenerates again or the filter backwashes (which can cause channeling of the bed). Then to get the bed back to full regeneration, you have to regenerate with the full salt dose for the volume and type of resin you have and then repeat it a second time with as little water use between the two as possible,
The max salt dose is 15 lbs/cuft of regular mesh resin. Any resin manufacturer's web site will support what I'm saying. Go here to ask your question and see:
http://www.puroliteusa.com/fr_bulletinboard.htm
If your softener is not set up for 15lbs/cuft, which most are not, then you have to manually add water at the rate of 3 lbs/gal to the brine tank for the difference between your salt dose and the maximum/cuft of resin. Not fun IMO. Say you use 6lbs/cuft, that's 2 gals of water so you'd add 3 more gallons; both times.
So the best choice is to unplug it/them and do a manual regeneration/backwash (not at the same time; one before the other soon after returning home and I suggest the filter first, it's usually about 20 mintutes until finished.
Gary Slusser
UNKNOWN 16 T/A TRASH TRAILER (A53843)
UNKNOWN 16 T/A...
2017 Ram 4500 Bucket Truck (A53473)
2017 Ram 4500...
2004 Ford F-250 Service Truck (A53422)
2004 Ford F-250...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2016 FREIGHTLINER...
