Water distribution to a bunch of newish fruit trees?
   / Water distribution to a bunch of newish fruit trees? #11
We put in 20 trees last spring and ran 3/4" black plastic pipe trenched at about 6" down with a 2gph pressure compensating emitter at each tree and a 24" piece of emitter tubing with 4 0.5gph emitters in it in a loop buried around the tree.
We hook a timer to the pipe and connect a hose to that. That way we can give them about a gallon of water per day by running the hose for 30 minutes.
This year we need to add something similar for the garden.
Aaron Z
Aaron Z
Have you had any issues with the buried emitters clogging?
   / Water distribution to a bunch of newish fruit trees? #14
For portable, six-month to one-year irrigation use T-posts with sprinklers on top, supplied by garden hose. We use hose Quick Couplers on the feed hose, moving from one sprinkler to the next. With ten foot tall T-posts you have really wide coverage, maybe 50'. We use this irrigation hardware in our 1-1/2 acre Blueberry field. Simpler, cheaper than drip.
I recently ordered one of these Yuzuak (brand), Turkish manufactured, plastic impact sprinklers combined with a Sprinkler Innovations (brand) industrial strength T-post fixture. No sprinkler leaks. Very precise adjustment of spray splitting. No zinc in the T-post fixture; only steel and brass. The best impact sprinkler and the best T-post fixture I have yet found. Well worth the somewhat premium price.
Now I can precisely overhead irrigate twice the surface, moving the hose from T-post sprinkler to T-post sprinkler once every 60 to 90 minutes, instead of every 20 to 30 minutes.
I have standard, residential 55 psi water service. No pressure boost.
SPRINKLER FUNCTIONS ONLY IN 360 MODE.
SPRINKLER HAS NO MECHANISM TO OSCILLATE.
LESS IS MORE.​
Not offered on Amazon.
   / Water distribution to a bunch of newish fruit trees? #15
A tree should get about an inch of water per week, whether naturally or via irrigation. A cubic foot of water contains 7.5 gallons. A 3 foot circle is 7 square feet. That figures out to about 4.5 gallons of water per tree.
As Moss said, improper irrigation promotes shallow roots. You are better off to rotate your trees, so that over the course of a week they each get watered once.
   / Water distribution to a bunch of newish fruit trees? #16
We planted a bunch of new fruit trees last year to replace gradual die-off from an old orchard, and also to add more varieties... and mostly because it sounded great and I'm an idiot and let people talk me into adding to my workload.
Last year I set up a temporary watering system using a few runs of ?5/8"? (0.7" I think actually) drip line with 1/4" coming off to each tree, and some tubing with 6"-spaced emitters in a circle around the new trees for 3gph run for a couple hours every few days; these are connected to a hose bib via battery timers.
This generally worked, but it was a mess and was obviously impossible to mow around. I'm looking to put something in that's permanent.
My thought at the moment is to rent a smaller trencher - 4" wide x 24" deep max.
Frost isn't an issue, as watering only needs to be done in late spring through fall, and there will be no water pressure at any other time.
Thought is to run pipe down the lines, and T more pipe to each tree, and have a stub-up where it won't get hit by a mower, and attach drip w/ emitters for now, and maybe bubblers later.
Biggest question is: Can I use poly pipe for this? It's cheaper and quick & easy to handle... are the joints reliable to put underground?
I also like the fact that poly is flexible and can tolerate less-than-straight "lines" better (our orchard isn't on a perfect grid); I know pvc can bend some, but poly is very cheap and so easy to connect up.
Any advice for this noob?
An older master gardener told me what to do. Put down an old hose and drill a 1/8 inch hole where the tree is along the hose. Bury the hose just a tad and let grass grow over it.
   / Water distribution to a bunch of newish fruit trees? #17
I use the standard 1/2” drip line with emitters on the main line in my orchard. No 1/4” spaghetti lines. I make staples out of 9 gauge wire and fasten the drip line on top the ground. If it’s tight to the ground you can mow over the line with no issues, and being on top the ground it’s easy to find and fix leaks.
   / Water distribution to a bunch of newish fruit trees? #18
I hear that today. Digging up a leak in pvc for sprinklers in town. Of course, it is at an elbow.
Do you haul the system indoors in the Fall? At your elevation, I would imagine above ground freezes a bit.
   / Water distribution to a bunch of newish fruit trees? #19
No, polyethylene drip tubing is extremely tolerant of freezing. I jus T take the end caps off, so it has room for expansion.
   / Water distribution to a bunch of newish fruit trees? #20
Are all the trees in rows? Why not just run the drip line say at 3ft+ and let the drip line drip at the trunk. Easy to see, easy to work on and depending on the mower a 5ft high main line you can mow under.
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2025 JOHN DEERE 408R LOT NUMBER 10 (A53084)
2025 JOHN DEERE...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2015 KENWORTH T800 KILL TRUCK BOBTAIL (A53843)
2015 KENWORTH T800...
2004 MOBILE 500 BBL FRAC TANK (A53843)
2004 MOBILE 500...
