Water in the Flywheel area
   / Water in the Flywheel area
It is wise to leave an open hole near bottom so that condensation can drain.
That would be a good idea, but I don't think it has such a thing, since it had all that water in it still. A drain hole would have let it all out. It would still have caused a rust problem, even if the rain ran and and then right back out.
   / Water in the Flywheel area #12
I wouldn't throw anything at the flywheel and just let it stay dry.. glad you found the hole..
Apparently 2 holes. One on each side. I got my starter back this morning. The repair place did not put anything to seal those holes as far as I can tell. So I was thinking if just running a bead of silicone caulk along the top of that seam and covering/filling those holes in the process. Perhaps also throw some multi-purpose grease on all the parts that I noticed had rusted quite a bit on the outside of the starter over the last three years. I do that with my small trailer to all the electrical connections. The coating prevents oxidation but does not hamper metal on metal contact for a good electrical current. Hopefully all my futzing around to test the electrical did not cause further problems. (I'm looking at you, ignition switch)
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
2020 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A53426)
2020 KENWORTH T680...
1827 (A51248)
1827 (A51248)
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
