Somewhere else someone said that a 50ft garden hose has just about 1 gallon of water in it when full. His solution was to connect the empty hose to the adaper and tire, hold the other end of the hose high and pour the anti freeze in (perhaps with a funnel), then attach the hose to the faucet and send it in under pressure. Repeat as needed until full or you reach the desired number of anti-freeze gallons, then top off with water.
This could be tedious on say a 17.5 x 24 tire if you want/need maximum protection, about 33 gallons of anti-freeze and the same amount of water, drain the water from the hose each time to accomodate the next gallon of anti-freeze, so buying a 10 or 15$ tool might be a good investment.
I think I paid ~$7 for a drill pump.
FWIW, etc.
FWIW, etc.
