CliffordK
Veteran Member
- Joined
- Mar 8, 2013
- Messages
- 2,383
- Location
- Eugene, Oregon
- Tractor
- Toro D200, Ford 1715, International 884,
The well is unknown. I tried to find out some information from the county but they did not have any records of it since the well was put in, in the 1960's before they began keeping records on wells. Any ideas how to determine what I have water wise in the well?
Do you know how big of a pump you have?
Does the starter capacitor have a HP rating?
Have you ever pulled the pump (and thus know the depth) (and water depth, which can be significantly less than where the pump is located).
For your current pump, you could disconnect it from the pressure tank, then run it wide open and time how long it takes to fill a 5 gallon bucket.
That, of course, won't tell you if you can put in a larger pump and run a 6" irrigation line from it.
