Tires water out of rear tires
   / water out of rear tires #11
I almost hate to tell you this, and I have never done it. but You-tube is full of how to reseat the bead on tires. it involves a small squirt of wd-40 and light it from a distance.. POP/Bang, it is reseated.. in 2 seconds total time.Then air it up. I am sure if you put too much wd-40 in, you are in danger of losing your head or something else important. Use at your own risk.
James K0UA
Starting fluid makes a much better bang. Fill truck tires like that all the time. You might be able to put a ratchet strap around the outside of the tire to make it touch the rim to fill, but the other way is more dramatic. :thumbsup:
   / water out of rear tires #12
well i hope this will help you.first they make a pump to pump fluid out of tractor tires then when repairs are done they can pump the fliud in thru the value strem .but sence you already have it out and you just want to get tire to take bead this will work but it is very dangerous leave wheel bolted to tractor or chain to something solid that wont give it best to get air hose that will lock to valve stem squirt some starting fliud inside tire have some one throw a lit match on tire and wheel hit the air the same time match was thrown it will reseat bead fast but dont use very much starting fliud at all just a couple of little squrts will do it. you can use wd40, starting fliud,gas.hair spray but they areall very dangerous most service trucks that do tire repair have a tool called a bead blaster that uses air pressure that works really good with no explosion. in answer to your ? if the tires are loaded you get better traction and area big help on hill sides more stable.i just brought a new kioti tractor had dealer load tires they use beet juice i had never heard of this before,they told me thats what they recmend if you get a leak it wont eat your wheels up it seems to work fine with no problems
   / water out of rear tires #13
got water out but now I broke the bead on the tire need to call local tire shop for home fix has anyone tried to do this at home should i take the tires off the tractor and bring them in any idea on cost:)
i use carb cleaner and spray a squirt in the tire and around the bead and throw the match quick so it dont evaporate and cause fumes to float around for a huge explosion around the tire. Have water nearby incase residue burns or either beat it out with your hand. Be careful and wear safty glasses and long sleeves of cotton fabric. The ratchet strap wont work proabably, and if you can get a bead blaster it will work. but say 3 seconds of carb cleaner in the tire and a match will seat it and put several lbs of air in it. No the inside dont keep burning. And i would not use the air hose till all fire is gone.
   / water out of rear tires #15
i was draining the tires to get the water out since i have a backhoe for weight why would i refill the tires
Your question makes me think that you are new to the operation of BH's in general. yes?
The down force applied by the BH is only equal to the resisting force generated by gravity (unless you chain the tractor down). Without filled tires and often wheel weights too the BH will lift the back of the tractor before digging into the earth.
The side twist applied by the filled bucket + BH arms as you swing to dump is resisted by the weight of the tire/wheel on the opposite side. Yeah, there is a stabilizer, but it can only resist so much before the tractor tips over(or it sinks into the ground). What keeps that from happening? again, weight on the other side.
With BH's, the typical thought is how to get MORE weight, not less.
   / water out of rear tires #16
You're sure it was pure water and not calcium chloride/water?
The reason I ask is I have seen people inquire how to tell the difference.
How can you tell the differece?
   / water out of rear tires #18
You could also measure the conductivity with an ohm meter. Put some in a jar and measure the resistance across an inch. Compare to tap water.
   / water out of rear tires #19
:laughing:,,,or you could throw it on some ice,or ....But the tongue idea is the best.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
PALLET OF MISC PARTS & SUPPLIES (A58374)
PALLET OF MISC...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
3410 (A47477)
3410 (A47477)
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
CORN SHELLER MOUNTED ON WOOD BOX (A58374)
CORN SHELLER...
