JamesHW
Platinum Member
- Joined
- Oct 18, 2009
- Messages
- 527
- Tractor
- BCS 853 w/ loaded tires
We have a seasonal house in Upstate NY we close up every fall. Every spring hooking everything up would be a comedy of split pipes (despite draining them) unless I had carefully blew all moisture out of them first using a compressor, not something you want to do the morning before an eight hour drive. Since switching most of the plumbing to PEX I have not had any problems except for the year I forgot to properly drain the pump after unhooking it from the well and expansion tank. I just unhook the twist fittings I have strategicaly placed and let everything drain out. Then the hot water heater and the pump. Toilets get vacuumed out with a shopvac and then I flush half a gallon of the RV anti freeze and some into the traps. The whole process takes about 40 minutes.
I do not recommend pumping RV Antifreeze into the pipes. I thought it was a great idea, using a garden pump sprayer adapted to hook into the pipes, until the following spring when we hooked up the water and it tasted "minty fresh" for a over a week despite flushing many gallons of water through the pipes. My wife would take a drink, look at me and say "great idea champ" while rolling her eyes (the cracked pump was more fun).
