Water pump for Kubota L275
   / Water pump for Kubota L275 #1
goldenmama
Kubota L275
Does anyone know what the torgue on a water pump for a Kubota L275 may be? This is one item that is not in my manual? Thanks for any help!
   / Water pump for Kubota L275 #2
What size are the bolts? 6mm bolts are about 6 ft lbs, 8mm bolts are 20 ft lbs, 10mm bolts are 40 ft lbs, or one grunt before strip. I rarely use a torque wrench for things like a waterpump. The only time I might, is if I have the engine on a stand and had just rebuilt it and have the torque wrench out anyway.
Brian
So are you saying i can just tighten down the bolts with a socket no torque? I was just curious as it seems most everything else in the manual needed to be torgued. But if you are saying just put gasket on and tighten it down........would you use a sealer?
Goldenmama
   / Water pump for Kubota L275 #4
That is how I would do it, but I have been doing it a long time. And yes use sealer, I use either ultra-gray or ultra-black RTV.
Brian
Thank you for your help....i will purchase the sealer and hopefully get my kubota running again.
Pam (goldenmama)
New/Unused AGT MX-MRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
2008 Ford F-550 Reading Enclosed Service Truck (A52377)
2008 Ford F-550...
2006 CATERPILLAR 252B SKID STEER (A51246)
2006 CATERPILLAR...
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
6" & 8" I BEAMS UP TO 16' LONG (A51247)
6" & 8" I BEAMS UP...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
