I need a big water tank like the one in the link. All of the trees I'll use it for are going to be right off my driveway where I can get to easily in my truck. So, I'll just put this in my truck to water.
Makes sense ...... how many and how big are the trees .... and how many gallons do you plan on dumping on each one per watering ?
Reason I ask is, if you want this to go
quick, you need some
flow .....
Cheap and dirty way to accomplish that is a large hose ......
I couldn't get a straight answer from TSC or NT about how to actually hook up a water hose (or whatever) to actually get the water onto the trees.
LOL ... no plumbers there I guess .....
Anybody have any experience with something like this?
Yes .... I cobbled together a couple of 55 gallon drums that I mounted on a pallet to use for watering ..... grab it with my pallet forks and take it where I need to water.
I use the small holes on the drum lids (3/4" NPT I think) to to fill the drums (with a garden hose hooked to one drum, and the small plug out in the other, to vent) .....
Then I use the large holes (2") on the lids to drain (water) .....
What I did was install a couple of (large) 90 degree PVC elbows on the large holes in each drum ........ so that the elbows faced each other (drums are laying on their sides with the large holes at the bottom, small holes on top) .... in the middle, between the elbows, I put a PVC tee .... connecting both drums together with like .... 1 1/2" hose I think ....
On the third leg of the tee I ran a 15' (or 20' ?) section of (I think) 1 1/4" plastic flex hose that I think I got down at the hardware - was either for a sump pump ... or maybe for the drain on a washing machine ... something like that ....
At the end of that hose I stuck in a large PVC ball valve .... 90 degree On and Off ....
The advantage of using a similar set up and large hose is that
it flows a lot of water fast ... it's
easy and
simple ..... and it's relatively
cheap.
If you want to do something similar with your tank, what you need to do is cut a large hole on the side or end, near the bottom of the tank, and install a large through wall/bulkhead type fitting:
Through Wall Tank Fittings
