water to barn - 1" poly to 1/2" copper transition
   / water to barn - 1" poly to 1/2" copper transition #11
If you go to a plumbing supply you can get a compression fitting that will connect the two dissimilar pipes. The HDPE should have a bushing inside it to keep it from deforming and leaking latter which comes with the fitting.
Hose barbs and clamps is how it is done if you're ready to dig up in the future to fix the leak.
2013 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2013 FREIGHTLINER...
John Deere MX 8 Brush Hog, 8', 3pt Hook Up, PTO  (A52384)
John Deere MX 8...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52748)
2009 Lee-Boy...
WACKER NUESON PUMP PT2A (A52472)
WACKER NUESON PUMP...
2016 Ford F-150 Pickup Truck (A51692)
2016 Ford F-150...
