water treatment advice
   / water treatment advice #1
PaulieD
Bronze Member
Upstate NY (Adirondacks)
New Holland Boomer 35
Our Adirondack home is blessed with a great water supply (sustained 10+ gal/minute flow and no bacteria problems), but suffers from hard water and high total dissolved solids. Recently a friend introduced me to a Kinetco rep at a social outing and I decided to send the rep a sample of water and have him propose a solution.
The results of his water test determined that we have low iron, low oxidized iron and low manganese, but that we have very high levels of hardness and total dissolved solids (15 gpg hardness and 1285 ppm total dissolved solids). These numnbers were consistent with tests we had performed at an independent lab several years ago.
The proposed solution is a Kinetico 2030S water softener and a K-5 reverse osmosis unit. The total installed cost for the entire package is $4900. After doing a search and review of old threads, and doing some google research, it appears that the proposed solution is reasonable and appropriate, and that Kitetico makes a reputable product, but the $5K price tag is a little bit difficult for me to swallow.
I have no practical experience with water softening, just what I've gleaned from some internet research; and I was wondering if any of you might be able to advise me of options and/or share your perception of the kenetico proposal.
Thanks,
Paul
   / water treatment advice #2
I'm no expert, but we do have a Kinetico water softener. It's overpriced but works well and doesn't use much salt- our installer/service guy is good, but you can't fix the thing yourself- no parts etc. There might be better/cheaper options for a DIY type situation.
   / water treatment advice #3
If you have some spare time you could split the plumbing in your house. Toilets and bath tubs on regular water and smaller under sink units for drinking. Softened water contains salt and Dr OZ has told use to reduce our salt intake.
Craig Clayton
   / water treatment advice #4
... is a little bit difficult for me to swallow.
Pun intended? :)
Anyway, WOW, that's expensive water!
My experience with water softeners is this: I had well water that had severe iron & hard water deposits. My "tighty whities" were "tighty rusties". So, I bought a $900 (approx) softener from Home Depot around '96, installed it, had the water tested in order to know what settings to use. The results were that the water was extremely "slippery" feeling in the shower, tasted weird (un-natural), & the softener used way more salt than I thought it would; I'd have to buy as many bags as I could carry at a time, & HD (where I got them) is only 2 miles away. Now, it did "improve" (ie not eliminate) the iron sitting in the toilet & the hard water deposits around the toilet water level & faucets. Fortunately 3 or 4 years later city water came down our street & I was able to say good riddance to the softener. The city water has completely eliminated all iron & hard water deposits from the house.
   / water treatment advice #5
I have no doubt that Kinetico makes good water softeners, but I'm skeptical that they work that much better than the big box store brands like GE. I've had a Water Boss brand for 20 years and a GE reverse osmosis system (drinking only) for 8 years and both have worked great. Water is not as soft as "city" water, but toilets and showers are not rusty and soap washes off after a little scrubbing.
The reverse osmosis takes out the salt that the water softener adds.
   / water treatment advice #6
The results were that the water was extremely "slippery" feeling in the shower ......
That's because with soft water you are actually able to rinse off all the soap scum ..... and it's not leaving mineral residue on your skin .....
It's largely a matter of what you are used to .... ;)
Me, I've been on soft water for the last 40 years ..... drinking hard water makes me gag ...... :D
   / water treatment advice #7
When we built our new house we also had to install a softener and an R/O unit for drinking. We also have plenty of water, it's just quite hard and full of iron and sulfur. We chose the Kinetico because it does not run on electric and is very reliable. We paid just under $6k for our whole setup, but I have been very pleased over the past 2+ years.
   / water treatment advice #8
Yea, we've had many water softners over the years, our first one we bought in Va was a Rainsoft brand - another high-dollar unit - it worked well but no better than a much less expensive one. Our current one is a Kenmore we bought at the Sears Outlet in Nashville 4 years ago for $275 - it works just as well as any we've ever had. If you're getting salt in your water from a softner, there's something wrong with it !! A properly operating softner will not allow any salt into the system. Our water here is right at 15 parts on hardness too with just a trace of clear water iron, I go thru approx. 6 bags (300 lbs.) or so of salt a year - that's about $35 - $40 worth and we treat all of the water we use, not just a few fixtures. We use the iron remover formula salt - it's the same price as the plain. If you can do basic plumbing procedures and follow directions you can install either of the systems yourself and save alot in labor costs.
We had a small undersink RO filter unit at our house in Florida that did just the kitchen sink and icemaker in the refrig - it cost about $200 originally and filters once a year were around $50. A whole house unit would obviously cost more but I can't see $5k for the 2 systems. I think I would shop around more and see what's out there.
   / water treatment advice #9
That does seem hellishly expensive, even by Canadian standards... ours was under $3k installed. Excalibur softener, it has a water meter so it only re-generates when needed instead of time-based. Also a reverse osmosis to remove salt and anything else the softener doesn't get. Best water I've tasted in a long time.
Those are really high dissolved solids numbers !
Sean
   / water treatment advice #10
The softner should not be putting salt into your water. It only uses the salt to regenerate the ion exchanger, then it should be flushed out. There may be a little residual salt left over but I don't think they actually add much actual salt to your daily intake.
Kinetico is top notch and the most expensive. There are softners out there that are cheaper that will do a good job.
Stay away from the Big Box Stores softners.
3 Point Metal 4ft Cargo Carry (A51573)
3 Point Metal 4ft...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
2016 FORD F450 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F450...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
