Water Wagon Tow Capacity
   / Water Wagon Tow Capacity #31
My Kubota M7040 manual has the same type of language. Indicates it can pull a trailer with 11,000lb load (not including the trailer weight). So, I guess that means I can pull an 80,000lb train car, but I just can't put more than 11,000lbs on it.
I think what they are getting at, is you can tow an 11k trailer loaded to the max. Since they have GOT to be taking the trailer weight into account, they are probabally just assuming that most 11k trailers will weigh roughly the same.
And as in the OP' case, they are probabally assuming a set weight for a 1700lb capacity trailer. And factoring that in. Considering there souldnt be a whole lot of weight difference in the various different trailers of that size.
In YOUR case, they are probabally basing it on a 14k or 16k trailer, figuring the trailer weight makes up the difference.
But I could be totally wrong too. Maybe you can indeed (according to kubota) pull an 80k trailer as long as you keep the load under 11k.
   / Water Wagon Tow Capacity #32
Hi Guys,
Thanks for the quick replies.
Smallplot, I see your reasoning but I think 60 gallons of water might be a bit to conservative for the BX-25.
60 gallons at 8.34 pounds is around 500 pounds. I think the backhoe itself weighs more than that.
The little hoe is FIXED and becomes (almost) an integral PART of the tractor's mass.
The added weight is BEHIND the rear axle, so it exerts more than it's actual mass on the rear tires.
60 gallons - or FAR WORSE 40 gallons in a 60 gallon tank - slopping around on the hook is going to be a very different story.
Your money, your choice, your destiny (your azz at risk),,, but I wouldn't.
   / Water Wagon Tow Capacity #33
I just looked at the link for the Kiser Wagons. If you click on their Models/Specs tab and scroll down to the section marked Min Tractor HP (Level Terrain) is shows 20HP 4wd for the 200gal and 25HP 4wd for the 300 gal models. And that is on LEVEL TERRAIN.
As far as if the BX25 can pull larger trailers, I can push or pull a car (using man power) sitting on a flat parking lot, If that same car is in a yard, I still may be able to depending on how much it sinks in, but i would not be able to push or pull it up very much of a hill without someone helping me.
Just because I can pull or push the car don't mean I should, that is what tow straps and chains are for.......
In other words just because you can pull a larger trailer doesn't mean you should.
Good catch.
The Kubota BX-25 is a 23 Hp beast but my 54" Sears Craftman riding lawn mower is 26 Hp and I can pick the back end up a bit to get unstuck when it gets high centered.:confused3:
   / Water Wagon Tow Capacity #35
You said it, but you didn't even notice it yourself. Your BX-25 is a beast. Your Sears is "a riding lawn mower". I bet the BX weighs 3 times what the Sears does.
I've seen a front wheel drive mini van pull a 22' tandem axle camper. I can't say I've ever seen it try to stop however. Horsepower, especially in this respect, is totally meaningless.
   / Water Wagon Tow Capacity #36
Good catch.
There are several different ways Mfg's figure HP. With your Craftsman Lawn Tractor, it is more than likely figured at the deck for turning the blades (kind of like pto HP on a tractor). Where your BX will be figured in actual engine HP reaching rear wheels (just guessing here as I am not acquainted with either the Craftsman or Kubota way of figuring HP but sure someone on here can describe methods better). For instance your BX if equipped with PTO will have two HP ratings, one for engine HP and a second rating for PTO HP. The PTO HP is always lower than engine HP.
Secondly your craftsman was designed to mow yards and has the frame and tranny suited for that purpose. Your Kubota is designed to do more strenuous work, such as FEL or Backhoe work. Your Kubota has a frame and tranny suited for that purpose, thus your Kubota is built heavier and weighs more.
Hope this sheds a little light on the subject and if I am wrong, someone will surely point it out. :thumbsup:
The specifications page shows that the tractor engine rated rpms are 3200 with an engine gross hp of 23.
The rear pto rpm is 540 and the mid pto is 2500, but they don't say what the hp is.
So it looks like 200 gallon water wagon is easily doable and a 300 is on the outer edge of doable...on level ground.
I get the sloshing around thing. I won't be on any roads...all on pasture grass.
My pasture grass doesn't feel level. Just driving across it and you are kinda "bouncing" from all the little tuffs of grass and ground imperfections...so I guess my pasture has a lot of built in small speed bumps. :laughing:
   / Water Wagon Tow Capacity #38
HP is a calculation of work. Force/Time.
IF the craftsman has more HP, then it is capable of doing more work. OR, doing equal work in less time.
I know that is a hard concept to grasp. But HP factors time in. HP is NOT a measure of what can and cannot be done. Your tractor (BX) will simply do things the craftsman wont. Mainly due to size and gearing. BUT again, the craftsman can do more in less time.
I'll give you an example. My ZTR is 27HP. Your BX is 23. I can assure you that I can mow at a faster ground speed with the engine bogging less IF the same size deck and same blade speed is used.
   / Water Wagon Tow Capacity #39
Good luck. Besides one of the trailers you had referenced earlier I might suggest a cheap trailer from tractor supply and get the latest tank you can find. Keep it low to the ground as possible. If I understand you right, just watering trees, gravity flow will be fine and a pump really is not needed. That is putting water onto the ground at base of trees if I understand correctly. This would help keep the trailer weight down and if you find your BX has problems just replace the tank with a smaller one. A trailer, some hose, connectors, and a water tank would be cheaper than the trailer in your post.
   / Water Wagon Tow Capacity #40
The factor missed in your post, is torque.
Using your example of the ztr vs the bx. If yours is gas and 27 hp your actual cutting performance would be different than a 27 hp diesel. Why? Because horsepower is measured mostly in an unloaded condition. A loaded condition is reality.
Example - same deck widths but one is cutting 3 inch bluegrass and then cutting 5 inch bluegrass. Big difference in performance speed and numbers because TORQUE is different than hp.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2010 CATERPILLAR D6N LGP DOZER (A51406)
2010 CATERPILLAR...
Hyster H225E Forklift (A47477)
Hyster H225E...
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
200722 (A51247)
200722 (A51247)
