I was going to drill a well for my new house about 10y ago, using the
Deep Rock system.
I actually bought and used a Deep Rock well driller about 30 years ago. It was nothing more than a portable, 2-man, gasoline powered, post hole digger with special bils and extension shafts.
Anyway, we got down about 30-40 feet before we had to quit due to lack of further drilling progress, the hole was only 2" or 3" in diameter, and would have needed a special pump. We never really hit water and finally quit.
I was young and foolish at the time and would not do this again. I have read about the back injuries that these post hole diggers can produce if they hit something solid, and it is just not worth the danger.
I suppose a few lucky people have hit water with this kind of equipment, but it is not nearly as easy as they make it sound.
Going down is slow, but the other issue is that after the well is drilled, the entire assembly of bits and extensions has to be lifted out of the ground. This is very heavy and can be a real challenge. Be sure to have some way to secure the part still down the hole from falling while you are unscrewing each section. It has no good handholds, and if you drop 80' of steel pipe back down a 100' hole, you are going to have a real problem getting it back out...
