Water Wetter?? Any final comments
   / Water Wetter?? Any final comments #1
SheriffSRB
Oconee Co Georgia
Yanmar 1500D
Before I use it in my 1500D?? I am picking it up on Friday (I just can't get up there to get it before then) and after all I have read I suspect it is the way to go when it comes to cooling these tractors. Of course when it gets cold I will add antifreeze, unless my wife lets me keep it inside.
   / Water Wetter?? Any final comments #2
Sheriff,
I've not read or have any information on Water Wetter but I suspect its supposed to move the heat more efficiently from the metal of the engine to the coolant and then to the radiator thus enhancing heat removal. I have read that ordinary dish washing soap will do that. I haven't tried it as I don't have a heating problem with my 1500 here in central Arizona. These are well engineered tractors and my suggestion is to see how your tractor works before making changes.
Bob
   / Water Wetter?? Any final comments #3
I've never heard of "Water Wetter". What is it, who makes it and what does it do? That's what I like about this board, always learning something new.
Thanks Bob, I guess the volume of cooling questions was leaving me a little concerned. Glad to know you are not having any problems.
I will keep you posted.
I will be bush hogging and smoothing my driveway with the tractor, and overheating this little unit is just not on my mind
Check out Water Wetter in any of the search engines. It is a additive that reduces the surface tension of regular water and enables it to cool an engine down better than antifreeze or just plain water....
   / Water Wetter?? Any final comments #6
The reason that we read of so many overheating problems with the 1500's is that we are accustomed to either a 50/50 mix of antifreeze or, in later models, 100% antifreeze. My 1500 had 100% antifreeze in it when I got it and it overheated as soon as I used it.
The manual for the thermosiphon models such as the 1500 call for no greater than a 40/60 mix. I drained the system and added a 33/66 mix (1gal anti-freeze to 2 gal water) and haven't had any overheating since.
Thanks Ozarker...I suspect when I pick up the tractor I am going to change all the fluids, filters, etc...including draining the radiator and starting over again.
These look like great little tractors, I am glad to be getting one.
   / Water Wetter?? Any final comments #8
I really like my little 1500 but sometimes I get a envious when I see the newer tractors some of these guys have. But then I remember that I didn't even come close to spending 18K and I get over it.
It is my very first tractor and it has done everything I have asked it to do. The only limits so far have been my lack of experience in using a tractor. Of course I am not farming and just use it to maintain my drive, push snow and do all the little landscaping jobs on my honey-do list.
For something that was built in the 70's and spent the first 20 years of it's life in rice fields, it is a great little tractor.
   / Water Wetter?? Any final comments #9
Ozarker,
I hear ya Buddy, my 1700 did me well for 3 years. Then I got the itch for the FEL, Hydro, 4WD............you know. I figured if there was any better time im my life to get one, it was last year. Thats when I bought my TC18. I miss that little Yanmar though /forums/images/graemlins/crazy.gif
   / Water Wetter?? Any final comments #10
I ordered a translated manual for my 1500D and it said to run distilled water only in the radiator during the summer months. The only time you were to add antifreeze was during the colder months to prevent freezing. They were vague about the mix, but 33/66 sounds good to me.
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
20' Multi Door One Way Ship Container (A52384)
20' Multi Door One...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
