Way to start off the week
   / Way to start off the week #11
looch, what year model is your Jetta? Did you add the heater after market?
I have a 2001 and did not come with a heater. On our extreme cold mornings here in North Texas /forums/images/graemlins/grin.gif about 32 degrees, it tends to grunt pretty good when starting. I have had it checked out several times and it checks out fine. It gets the same full my tractor and my Dodge Cummins does and they have no problems. Of course the tractor and the Dodge don't get 52 MPG.
   / Way to start off the week #12
</font><font color="blue" class="small">(
Junkman, when it gets really, really cold something happens with fuel. Exactly what that something is, I'm not 100% sure. What I can say is that on my Jetta (which has clear fuel lines) when it's this cold, and if I haven't added any fuel conditioner, I see little bubbles in my fuel lines. The engine does not appreciate this interruption in fuel delivery. I am assuming this is what was going on with my tractor. )</font>
Let us look at this "phenomena" reasonably.... If you are getting air in the fuel lines in the winter, then why wouldn't you get air into the fuel lines in the summer. Air has to be introduced into the lines somewhere between where the fuel exits the fuel tank and the injector pump. If it is sucking air when the engine is running, then it will be leaking fuel when the engine is off. I don't know what you are seeing in the clear lines, but I am certain that it isn't air. If there is air in the fuel lines, then the engine will not run. I think that the person that suggested it might be wax has the correct answer. Wax forms when the temperature is cold enough to separate it from the rest of the oil. Adding a treatment to the fuel causes the wax to dissolve and mix with the additive which in turn lowers the temperature where the wax will crystallize again. If you were able to get the treated fuel cold enough, say -50 degrees Fahrenheit, it might just form wax crystals again. Hard to imagine, but it can happen.... air can't.... that is my story and I am sticking with it... /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif
   / Way to start off the week #13
</font><font color="blue" class="small">( I do use additives in my car and I know they can damage the fuel pump because of a lack of lubrication. )</font>
From what I have learned and can gather from reading the differant manufactures information, on the differant addatives available. Most good quality addatives available (power service) and I am sure there are others. They have the necessary ingrediants in them, to help provide for proper lubrication.
   / Way to start off the week #14
Ah -yes... Power Service. Made right here in Weatherford Texas.... Now there is an American success story.
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
2020 DRAGON ESP...
2001  WABASH 53FT DRY VAN TRAILER (A57880)
2001 WABASH 53FT...
2019 Ford F-550 (A55973)
2019 Ford F-550...
