weak/slow hydraulics l 48 kubota
   / weak/slow hydraulics l 48 kubota #11
I'm sorry I have been busy working it, I got the dealer to print me a parts list out of the hydraulic system, since I have good pressure they want to run a flow test and check the suction screen, they did tell me the loader does not have a relief valve , there is one at the main block below the loader frame and one under the seat and one main in the backhoe control valve, it could be as simple as a bad o ring or debris in one of the quick disconnects, thanks for your help JJ and Lee John I'll post back when I get it figured out dale55
Did you also get the parts list for the backhoe control valve? I couldn't find the main relief in the backhoe valve see if it's in your list. There is none in the loader valve like they said, I think I said there was one before and I was wrong there, it's in the hyd. outlet block.
   / weak/slow hydraulics l 48 kubota #12
The first relief valve will be the master relief. Should be before the first valve .
The reliefs on my Kubota is on the hyd block, log splitter valve and 3pt. I don't have a loader on the tractor.
Some tractors might only have a pump and 3pt valve with relief.
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53473)
2023 NEW HOLLAND...
JOHN DEERE 850K LGP CRAWLER DOZER (A52705)
JOHN DEERE 850K...
2015 FORD F250 SUPER DUTY EXT. CAB (A53843)
2015 FORD F250...
3 BATTERY CHARGERS (A53843)
3 BATTERY CHARGERS...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A54607)
2007 PETERBILT 379...
