Weed problem along garden fencing
   / Weed problem along garden fencing #11
I have not found torching to be very effective, you are just mostly killing the top growth and it just comes right back. I saw somewhere on line where carpet remnants were used and it was very effective... looks a little 'trashy' to me. Maybe something like old rubber conveyor belting... it is heavy enough to stay put and probably will take many years to breakdown if at all.
Ordered a Weed Dragon this afternoon. Will see how that works out. 420 reviews and 9 out of 10 reviews were very positive. Doesn't have to kill them I guess, just cause them to quit growing:)
   / Weed problem along garden fencing #13
I use three passes with the burner. One to "size 'em down", one to further shrivel/blacken, and one to blow the ashes away. Gave up a kero-powered English burner from the '60s for HFT's propane model, using a 'high pressure' regulator (12-18 or so PSI?) from TSC to full effect with 20lb tank. VERY efficient time & $$ wise. (You'll love the WD and the Mrs will love you for finding it.) :)
   / Weed problem along garden fencing #14
Roundup is safer & better than a homebrew. It's been tested for safety & effectiveness and the weeds it will kill are listed on the label along with all the precautions. Homebrew? You don't really know what the chemical reactions of the combo will be and you don't know what you will get.
   / Weed problem along garden fencing #15
Roundup has been linked to causing Cancer recently.
   / Weed problem along garden fencing #16
Yes, the World Health Organization says it "probably" causes. Doesn't mean it really does. The risk comes from using it on "Roundup Ready" crops. Are you going to eat the weeds you spray? Roundup does nothing in the soil; and it rapidly degrades in the soil. It enters the plant thru the leaves and is transferred inside the plant to the roots where it interferes with an enzyme that is only found in plants. Roundup has been in use for over 30 years and is the most widely used herbicide in the world. If Roundup were to pose a significant problem on the scale one would use when spraying along a fenceline, it certainly would have been found out by now. If after all those years, all they can come up with is "probably" I wouldn't worry about it for a fenceline.
   / Weed problem along garden fencing #17
Nothing better then Roundup, or the cheaper versions of it. I buy it in the 2 1/2 gallon concentrate for $49 at Atwoods and go through 4 to 5 of them a year. You can spend a lot of time, effort and money using something else, but in the end, it wont be as good.
Eddie
   / Weed problem along garden fencing #19
I've used roof tab shingles under chain link and stockade fencing to reduce/eliminate mechanical trimming. They last much longer than 30lb felt, and stay put. Little bit of fuss at first, getting them to settle-down and kill what's underneath, but only need to be touched up every 5 yrs or so. Mower decks that are wider than wheel track won't disturb them by not driving over the tabs. Line trimmer gets used a LOT less if at all, and the look from afar resembles that of a carefully applied glypho 'chem-trim'.
Common complaint of "I sprayed and they came back" shows that 'chemical trim' may only account for actively growing weeds vs dormant seeds. Weed burners are great for some sensitive locations, aren't a permanent fix either, but are very effective if you 'burn' ~half as often as you mow.
btw, This could be simpler than having the little lady ask for chemical-free bug control. (always take the easy one ;)) tog
:thumbsup: for the shingles
   / Weed problem along garden fencing #20
Vinegar is pretty much in the category of a 'wives tale' for me. Vinegar is about $2.50 gallon for a 5% solution and you have to soak the ground so the roots uptake the solution which kills the plant.... at that high cost and low coverage area per gallon you might as well just pull the weeds by hand.
Glyphosate runs about $50 for 2.5 gallons of 41% solution concentrate. That works out to about $.31/gallon when mixed at 2oz/gallon and all you have to do it get some on the leaves so the coverage area is vast compared to something like vinegar.
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
2008 Chevrolet Express Cargo Van (A52377)
2008 Chevrolet...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
