weed trimmer 3-point hitch
   / weed trimmer 3-point hitch #1
tglass
Platinum Member
3320 w/cab
Has anyone made a weed trimmer that fits on a 3-point hitch? Need to get some input on this. Do's and don'ts. Thinking I can make one that is hyd. driven, spring loaded to go around t-post, and with a hyd. cyl. to make it extendable to get around the delicate places in the yard. Single square tubing with two sizes to make it extendable. Have a 3320 Deere to hook it up to so think I have enough hyd. to make it work.
   / weed trimmer 3-point hitch #4
Poo,
I looked at your site and the reference.
That looks like a lot of work to make it happen. You could simplify your design and reduce costs if you dropped the PTO part and simply mounted a lawn mower motor on the end of a spring loaded arm. Mount a hub on the shaft of the motor that will hold 5/16 or 3/8 cable.
Rather than try to weld it, you can have swedges installed. I'd make sure those are tightly installed---you don't want them flying off. Maybe you could use 1/4" chain????
You would need a protective ring nearly the diameter of the cutter, so that it could rotate back when it hits an obstacle.
I'd also want a HUGE deflector shield to protect the tractor and operator............ And make sure no humans & animals are near when you use it........
Hope this helps.
ron
   / weed trimmer 3-point hitch #5
I'll probably just take an electric weed eater and mount it in the proper position
and power it off the tractors electrical system via the power inverter.
Instead of trimmer string use one of those blade attachments.
Pooh Bear
   / weed trimmer 3-point hitch #6
</font><font color="blue" class="small">( I'll probably just take an electric weed eater and mount it in the proper position
<font color="red">One of the problems with a weed eater is they are a vertical reach instrument.
For a tractor you need a horizontal reach implement. </font>
Pooh Bear
)</font>
   / weed trimmer 3-point hitch #7
</font><font color="blue" class="small">( Has anyone made a weed trimmer that fits on a 3-point hitch? Need to get some input on this. Do's and don'ts. Thinking I can make one that is hyd. driven, spring loaded to go around t-post, and with a hyd. cyl. to make it extendable to get around the delicate places in the yard. Single square tubing with two sizes to make it extendable. Have a 3320 Deere to hook it up to so think I have enough hyd. to make it work. )</font>
<font color="green">::::::: </font>
<font color="brown">Click on my screen name in this post.
Then click on Show all user's posts.
There are several threads related to this subject in the list that comes up. </font>
Poo, the weed chopper is kind of what I had in mind using a hyd. motor to power it intead of the pto to eliminate the problem making it extend hydraulicaly and swing around t-post. Problem I see with a engine mounted on the end is the clearance between it and the fence wire. Have a Swisher pull behind trimmer, but it will not extend and is hard to get in those tight areas.
   / weed trimmer 3-point hitch #9
Yeah, I would rather do hydraulics too.
But my tractor doesn't have remote hydraulics (8N).
So I would have to use an engine mounted pump or pto pump.
I'd love to have an engine mounted pump (Zane Thang).
But finances just don't allow that to happen.
So I'm thinking electrically.
Either AC via an inverter or DC via tractor electric or seperate PTO driven system.
Pooh Bear
Now I'm thinking DC via tractor electric sounds like the cheapest and easiest in the long run figuring all the nickel and dime things involved that adds up quick. Has anyone had a post of a cheap motor capable of running one? The rest would be simple to rig, and cheap enough to build.
John Deere Imatch Quick Hitch (A50514)
John Deere Imatch...
2013 Toyota Prius Hatchback (A50324)
2013 Toyota Prius...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
2011 New Holland B95B Cab MFWD Loader Backhoe (A52128)
2011 New Holland...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
