weed trimmer 3-point hitch
   / weed trimmer 3-point hitch #11
An old clothes drier motor would probably work.
Don't know about a motor out of an old home HVAC unit.
Both of these would need a power inverter to run off the tractor.
How about a blower motor out of a cars heat/air system.
Would it be powerful enough. It would be 12 volt.
Maybe a starter off a small car. Mite pull too much current tho.
Otherwise look thru the Surplus Center catalog. (or online).
Pooh Bear
   / weed trimmer 3-point hitch #12
I had an interesting idea for this.
Instead of using weedeater string or wires or cables,
why not take a small disk, about 12inches in diameter,
and mount 4 or 5 sickle mower cutter blades around it.
Then mount the disk on a shaft and use it to cut high grass/weeds.
I have attached a picture of what I am talking about.
Pooh Bear
   / weed trimmer 3-point hitch #13
That would scare me to be near it running. Too easy for the rivets to break loose and suddenly you have a flying sickle blade.
One ag mfg made a hay cutting machine that used a disk similar to your design, then had maybe 10 three or four inch long blades attached. The blades were captivated by a metal bracket and a pin or bolt through the blade and bracket.
To me, that would be safer than trusting rivets.
ron
   / weed trimmer 3-point hitch #14
How bout we all slow down here a second and keep it all simple and safe lol. First all you dont need a gear box to do this. Ive made an offset mower for some customers that are mydesign. You take 2 flange or pillow block bearings and mont a shaft in them with a large diameter pulley then adapt it to your pto shaft. Then make a side arm out of angle or pipe or whatever then mount a spindle out of an old lawn mower deck for a heavier one use a finish mower spindle unit or for a heavy unint make one from a pipe and some tapered bearings. You can use the belt as it allows you a half tun in yourdrivelin to eliminate your gearbox and the belt. I made one that had a pivot under the pillow blocks to let the shaft pivot a bit in case of an obstruction but thats not needed either. Around posts we just used longer strings. For blades we used the same design as above but used an Australian hay disc mower as a pattern. It used on disc and the same 2 inch blades as a long bar style disc mower but it had one 3 foot drum with 4 to six swinging 2 inch blades. I made mine smaller about 20 inche with the four 2 inch blades to make the thing come out to a 24 inch cut. works good and the blades have alot of give as it has them free swing.
This sounds interesting, and possible to build. Have you got any pictures or scetches of it?
   / weed trimmer 3-point hitch #16
I didn't mean to rivot the blades to the disk.
Use small bolts and bolt it to the disk.
Each blade has two holes for rivots. Just use bolts instead.
I can't see it being dangerous at all.
Keep people away from it when it is running.
Pooh Bear
Pooh, looked at the weed chopper you referred to, but couldn't get any specs., or prices. Never hurts to look or ask, and tried several small elec. motors, but just didn't have the power to do much. PTO still might be the cheapest if you could find a cheeep enough box to turn it 90 and then the cost of a cheap driveline. Still looking.
   / weed trimmer 3-point hitch #19
There's a good reason you can't find prices.
I remember seeing the price for one but don't remember what it was.
I do remember it was ungodly expensive.
Friend of mine gave me a sickle bar mower.
I got to go get it. But I may not need a weed chopper.
Pooh Bear
   / weed trimmer 3-point hitch #20
Pooh Bear
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
19011 (A48082)
19011 (A48082)
Irrigation Pump (A52128)
Irrigation Pump...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
