weight of concrete
   / weight of concrete #21
I had to move it at the 3 day mark. It was just in my way. I didn't plan well ahead. My shop floor was the only place I had that was flat and the barrel wouldn't get rained in. I lifted genly and didn't bump it at all when I set it down. Need to finsh up the 3/4" lift pins/rod today and get it ready for log work.
Thanks again to all who have had informative input.
CB
Those 3/4" pins will be plenty strong, but will probably bend slightly upward over time and use. Set your linch pin holes to hold the lift balls pretty close, but not hard against the barrel. ... Say, leave room for an inside washer - and maybe outside too if you like. Thatll leave some breathing space to make adjustment if slight bending occurs.
larry
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2005 CATERPILLAR 740 - 6X6 OFF ROAD WATER TRUCK (A52706)
2005 CATERPILLAR...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
