Weight of Pressure Treated Lumber
   / Weight of Pressure Treated Lumber #1
George_W
Does anyone know the approximate weight per foot of 8x8 pressure treated SYP piling/timber? I'm guessing around 20lbs/ft but cant seem to find a reference anywhere.
   / Weight of Pressure Treated Lumber #2
Southern yellow pine can vary between 31.8 lb/cf to 38 lb/cf. Add in the weight of the treatment and adjust for the true size of the 8x8. That will give you an estimate of the weight.
For example, if the 8x8 was CCA treated to marine spec, you would add another 2.5 lb/cf to the weight. I think a nominal 8x8 is actually 7.5x7.5. If so, that means you'd adjust the total cubic nominal footage by .84 and then multiply the total actual cubic volume of the 8x8 by the total of the treatment weight and the density.
Thanks Darren. Is that cubic foot or board foot?
   / Weight of Pressure Treated Lumber #4
That is cubic foot but a board foot is also cubic measure but is nominal rather than actual.
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
1999 International 4700 Dump Truck, VIN # 1HTSCAAN3XH660516 (A51572)
1999 International...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
CAT Skid Steer Grapple (A51573)
CAT Skid Steer...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
