Ballast Weights for front of GC2410
   / Weights for front of GC2410 #1
dc23768
Wells me
gc2410
I find htat my gc2410 is a little light in the front
Any one know where I can get some wheights for the front end
   / Weights for front of GC2410 #2
Yes, the dealership, its a rack style wight that sits on the front bumper. I remember seeing it in the MF access. brochure.
That doesnt work for me you cant have the Loader on it when you put those weights on
Thanks
   / Weights for front of GC2410 #4
Foam filling the fronts can add a little weight. Each tire ends up about 60 pounds. It helped me a lot with steering control while using a rear snowblower.
Dennis
   / Weights for front of GC2410 #5
Dennis
Are you sure?
I don't think they would weigh that, if you filled them with lead.
They are not very big.
   / Weights for front of GC2410 #6
Thanks
Why don't you just put something in the loader then????
   / Weights for front of GC2410 #7
Exactly, I assumed he needed the extra weight because the loader would be off.
With the loader on you can add at quite a bit of weight-unless of course you want to use the loader. Maybe manufacture a mod for the top of the loader that will allow you to mount the weights and use the loader at the same time?
   / Weights for front of GC2410 #8
With the fel and b/h on it, it's only too light in the front, if your doing something it was not designed to do, like pick up a lot of weight with the b/h extended.
In which case, you can fill the front bucket with gravel, etc., first.
   / Weights for front of GC2410 #9
As they are 10 inch wheels you could look around for some old garden tractor wheel weigths. Then you could bolt them on the front wheels. If memory serves they weigh about 30 pounds each. Another option is to make a bracket and use free weights as needed.
SAKAI SMOOTH DRUM ROLLER (A52709)
SAKAI SMOOTH DRUM...
11' CONTAINER (A52706)
Dump Hopper, 43" W x 39" D (A59076)
Dump Hopper, 43" W...
2018 John Deere Z997R (A53317)
2018 John Deere...
Cummins DGCB 60 kW Standby Diesel Generator (A56857)
Cummins DGCB 60 kW...
TUGGER TRAILER (A58214)
TUGGER TRAILER...
