IH3444
Veteran Member
- Joined
- Jan 10, 2004
- Messages
- 2,116
relax, and rest easy Eddie, you are doing everything as right as can humanly possible be done. Me thinks you are going to windup with a great engine for the rest of your life.
When spinning out the old upper half shell main bearings, use this trick. Do one at a time, place a roofing nail into the oil passage hole in the crank, turn the engine over so that the tab on the bearing shell exits first. Install the new bearing in reverseing order. You will be able to get it started, and almost installed by hand, but use the roofing nail to help slide the bearing into place, and seat the tab. The thin head of the nail is needed so that it clears the block journal while rotating around. As well as not able to slip into the oil journal hole.
