Taylortractornut
Elite Member
- Joined
- Mar 27, 2002
- Messages
- 2,770
- Location
- Iuka Mississippi USA
- Tractor
- 3550 Fard Backhoe and a 1948 Farmall Cub,
I used to build custom cylinders and repair them for a company I worked for. It can be welded and fixed. Just clean it reallyh good with thinner or either and then rinse it with a good degreaser. SOme times I use a torch to burn some of the grease out of the pin hole then grind it out with a nice flowing v . A sharp V will likely make a great flux trap. Becareful of under cut at the end of the weld. I usually make my first pass in the V then let it cool and chip the weld. Then I usually make a cover pass just for extra precaution. I ve only had 2 that still pin holed but Later fixed one. THey were both on Sellick Fork lift side shifts in a tie mill. The operator used the side shift to elbow stacks of ties over.
