Welding and its effects on the charging circuit
   / Welding and its effects on the charging circuit #1
Retrorod
Australia
Countax
I have a John Deere ride-on that cracked its mower deck bracket. Without thinking, I welded the thing, without disconnecting the battery connections.
The alternator does not charge (it may have been like this when I purchased it, but I do not think so).
I suspect that welding the mower deck as I have, I may have damaged the AC to DC regulator:thumbdown: . Does anyone agree? If so, where may I locate this device?
Thank you to any interested member that can put me on the right track. RR
It was remiss of me to leave out the mower details. It is a L110 John Deer with a 17.5hp Kohler engine. Thank you.
   / Welding and its effects on the charging circuit #3
Depends where you had the ground cable. I know they "say" you should disconnect the battery... but the weld current will tale the path of least resistance- directly from electrode to ground. I weld all of the time on industrial equipment with much more sensetive electronics and have never had a problem. Again, they "say" you should disconnect power, sometimes I do to be safe, but many times I forget... besides it only disconnects line voltage but does not open the path through the other electronics so I never saw much point.
   / Welding and its effects on the charging circuit #4
I once welded a nut on a goose neck hitch in the bed of my truck. I put the ground clamp on the hitch and burnt out the electric oil gauge. Now I try to always pull the ground cable and keep it from any metal. "The path of least resistance" is not always the problem, 12V gauges and alternators are not able to take anything close to that kind of amps any where near them. I would assume that a repair service could repair it for you.
   / Welding and its effects on the charging circuit #5
I have welded on all my tractors & my brother in laws without any issues. I always grind a clean spot and attach the ground directly to what I am welding. Never had any electronics go bad.
Your experience may not be the same as I have "heard" of things burning out from welding.
I would never weld on something that is just a few inches or even a foot from sensitive electronic components though. EM waves of energy from the magnetic field created around the weld might just fry a gauge or computer chip. I don't think removing the ground would help in that situation either.
2013 ISUZU NPR STAKE BODY TRUCK (A56138)
2013 ISUZU NPR...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
2022 BMW X7 xDrive40i AWD SUV (A53424)
2022 BMW X7...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
