Welding brass with a TIG
   / Welding brass with a TIG
I have silver solder, but not a lot of it. Not sure if I can find the flux. Prob would want a nice tight fit to braze it. I was hoping someone would say "tigging brass is easy and fun". But I can braze or silversolder it, that would look right.
Wow that copper stuff is expensive. Saw a nice 1 1/8" Y fitting for $68. And most of the gutter fittings are 4" diameter and hundreds of dollars, like $300-500. My sink drain is either 1 1/4 or 1 1/2" currently going round&round whether to spend 2x $5 at Lowes or splurge $33 at onlinemetals.:D
   / Welding brass with a TIG #12
Sodo, do you have some scrap brass you can try TIGing various fitups and just see how well you do with it?
   / Welding brass with a TIG #14
Brass sink drains in 5 counties are trembling at the mere thought of my welder's power. .......maybe all I need is a BIGGER tungsten.... :thumbsup: OK here we go! Blue Demon 1/4-Inch Tungsten Electrode.
In the meantime I'll try grinding tungsten with the flapper disc that worked before (its in a ziploc baggie as the LWS fella suggested to me). My TIG kit came with 1/16" and 3/32" tungstens. What are the guidelines for using 1/16" vs 3/32"?
   / Welding brass with a TIG #17
It's all about amperage.
This book would be a huge help to you!
   / Welding brass with a TIG #18
If you have a Tig unit with Pulse, You can set the frequency at 1 pulse per second. That will give you all kinds of time to do a good job with out a meltdown. Practice will show you. Otherwise all of the other responses were good. Easy fix with oxy fuel and braze rod. Harris#5 as posted above will do it too. Also some of the low temp silver bearing solders out there will go liquid at 430 degrees. You can even do a second pass because the re melt is about 100 degrees higher. In the end the most simple way would be to braze it. You can blob it on and move it around pretty good if you are a torchman.
   / Welding brass with a TIG #19
Copper can be very easily plated with zinc to create an outer layer of brass. My kid did it for a science fair experiment, I bought all of the chemicals on Amazon. Instructions are here: Turn Copper Pennies Into Silver and Gold Pennies
   / Welding brass with a TIG #20
I use a dedicated 4.5 inch diamond blade on a dedicated angle grinder to sharpen my tungstens. Set the tungsten on the guard and roll it with my fingers so it hits the grinding wheel straight on. So far, so good.
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2022 Chevrolet...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A55851)
Dvorak Model 3072A...
SHOP SNAP ON TOOLBOX (A55745)
SHOP SNAP ON...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
