Welding on a rear axle hub
   / Welding on a rear axle hub
A 60th #60 sprocket is a little more than 14.75 in dia. My axle hub is right at 13 in dia. . http://www.embmfg.com/File.aspx?id=2fcf52b7-77fe-416b-bcdc-7d9ec50ca357&display=full uses a double 68 tooth, #60 sprocket which is around 17in dia. When this weather breaks and I get back in my shop, I have to do some measureing, but it looks like a 60tooth is probably the smallest sprocket I will be able to use. My plans are to mount the sprocket to the back side of the hub, but I might end up mounting it to the end of a axle shaft down at the bottom. Dont really want to mount to a axle shaft as it would require more fabricating, more bearings, and I dont know what else. Right now my rearend housing is covered in snow. I might try to pull the hub and get it in the shop where I can actually set and stare at it and come up with a plan.
   / Welding on a rear axle hub #22
I'm sure you know you will need to leave the axle on it with bearings at the differential end to hold the axle straight.
Dont think I am following you Brad. Right now, I only plan on using the hub and spindle and also plan on cutting the center section off the axle tube. The axle tube is sq and I plan on just making a base with gussetts to hold the tube upright.
It is a full floating axle..
If anybody has a small knuckle boom loader, I need to know the maxmium angle, with boom fully extended, that the boom will go down to. I figure on a maximum of 75* upright. I am trying to figure the mounting points of the cyl to the boom and the base. I am thinking about 25* below level and 75* up for a total of 100* lift.
Well, I thought I would post of pic of the hub, sprocket and base mount ready to start putting together. 0315151742a.jpg
Sprocket is a double row 72 tooth #60 and the base plate for boom is 3/4 by 20"dia
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
400 Gallon Fuel Tank with Stand and New Pump (A55787)
400 Gallon Fuel...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2014 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2014 Ford F-350...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
SDLL50 Loader (A47477)
