Welding - Stick Vs Gasless MIG?
   / Welding - Stick Vs Gasless MIG? #11
OHHH, You can also attach a TIG unit to a nice stick unit, Your gonna LOVE that! "bout the only thing you probably can't do is aluminum, And I'm not sure about that...You need AC and high frequency for that.
My TIG welder has AC and DC stick ability. It's a Miller APB330.
Your description above on stick welding is excellent and that's how I learned too. I find I too use my stick (either AC or DC) to do most, if not all my tractor welding projects. It's just to easy not to use. The only welder I don't have is a MIG, so I have no experience with it. In a different life, I was certified on TIG for plastic injection mold welding. But I really like the stick welders for most of my projects since most materials I use are a minimum of 1/4" and much thicker.
But this topic has come up many times so determine what you want to do mostly and get the appropriate tool for that.
   / Welding - Stick Vs Gasless MIG? #12
I'd stick with Hobart and lincoln as they are the best known and reliable. A machine can be sized by what you need it for. (DUTY CYCLE... the amount of time a machine can put out at full power.)I worked at a shop where they did a lot of sheet metal work, and the machines seldom got overworked. Now when he wanted to weld up an aluminum platform with a spool gun, that poor machine puked. He had an older lincoln TIG setup collecting dust in the corner that no-one knew how to use. He bought it at an auction and never tried to learn how it worked. We fired it up and I ran some stainless and aluminum beads to show him. I think he nearly fainted. A gas MIG is sweet for sheet metal and light guages as it's easy to learn, and QUICK. If you plan on aluminum, get a bigger machine with a bigger duty cycle. For the heavy stuff and delicate sheetmetal/stainless where weld appearance is important, I'd get a good AC/DC stick and save my money for a TIG add-on. If you need high production with light metal, you can use everdure (a brass/bronze alloy used with TIG) It is strong, and never rusts.
   / Welding - Stick Vs Gasless MIG? #13
I'm pretty fed up with of my little $90 stick welder and I'm thinking of getting a Gas/Gasless MIG. I've never used MIG but I'm guessing I'll be using the cored gasless wire most of the time. So I'm wondering whats the difference in ease and quality of gasless MIG compared to ordinary stick welding. Do you still have to chip the slag off a gasless mig weld? If gasless mig is not all that much easier than stick welding then its probably not worth me moving up.
Thanks for any comments.
Any flux core welding will have you removing slag.
A AC/DC stick would be an upgrade from what you have, DC is easier to weld with but the clean up is still there.
   / Welding - Stick Vs Gasless MIG? #14
Question for the experienced....
I'm going to start to learn to weld soon, and I'm really excited about it. I'm not the type of guy to 'cheap out', and I like to have capable and reliable equipment. I know I'll start with the easy stuff, but can see myself doing heavier stuff (implements, etc) soon.
What would your suggestion be for brand (I know Lincoln is a good name) and model or capacity of a MIG??
What about a plasma cutter?? From the bit of reading I've done I was thinking a 40A cutter, cause it'll cut up to 1" poorly, and 1/2" nicely. I thought those were reasonable limits for a home setup.
-Jer.
Hobart HH187, HH210, Miller MM180 or (MM211 soon to be at a store near you). Thease are all portable 220v Mig machines. Hobart Welders, Miller - Welding Equipment - MIG/TIG/Stick Welders & Plasma Cutting for all the specs.
I don't know which Lincoln models to look at.
40a plasma is a good choice, Thermal Dynamics, Hypertherm, Miller, Hobart, Lincoln, Esab
All good choices.
Stay away from the Chinese stuff.
   / Welding - Stick Vs Gasless MIG? #15
I have a 40 amp Hypertherm plasma and just love it. GIVE IT DRY AIR!!!
I have a small MIG that is very handy but it does not replace my AC/DC Lincoln.
Lincoln, Hobart, and Miller are all excellent NAMES in welding and may have good plasma cutters but... I sure do like the Hypertherm. I made the mistake of buying "just enough" plasma, or so I thought. I soon returned it to upgrade to the 40 amp which suits my needs so much better than a 20 amp unit. Better to have a little extra than not quite enough. The not quite enough approach was very frustrating. The Hypertherm (40 amp model) specs calls for a minimum of 6 CFM @90 PSI. There seems to be a capacity gap in easily available compressors. I ended up with a 10.x CFM @90 PSI as next after some 5.x models.
I have begun mounting or making carrying provisions for all my welders including the plasma and air compressor on a little 4x8 ft single axle trailer along with a 17,500 Watt generator to power it all. I was getting really tired of loading this stuff into various pickups or into various trailers and decided I would make a portable power and welding station on a trailer. Great idea, a little late in the grand scheme of things (boy how I could have used this sooner, years sooner) but still a good idea.
Pat
   / Welding - Stick Vs Gasless MIG? #16
Thanks for the help guys.
Stupid Q, but if a welder will do 3/8" thick metal, does that mean that you can really do 3/4 if you can get to the other side of whatever it is you're welding??
-Jer.
   / Welding - Stick Vs Gasless MIG? #17
LOL!!! i never thought about it that way! No, it is a function of the heat and size of bead the welder will produce. That's why aluminum takes so much current to weld, it dissipates the heat so fast that your in danger of cold welds. You can only cheat by preheating with a torch just so much...
   / Welding - Stick Vs Gasless MIG? #18
-Jer.
Well... not really. The metal being welded wicks away heat. Thicker metal does it more. 3/4 metal will be harder to get good fusion than 3/8 even though you weld both sides. You may end up with too cold of a weld ON BOTH SIDES.
Of course there are lots of situations where welding both sides is the best way to proceed.
There are certain minimum fusion requirements which just can't be practically achieved no matter if you weld both sides, even with multiple passes if your available power is too low. My 120 volt Lincoln Lunchbox (Weld Pak 100 MIG) is rated for up to 1/4 inch mild steel. While it can do that, it takes care and patience and works better with more than a single pass.
Think of trying to hop up from one step to another with a hop height of 6 inches and a step height of 7 inches. No matter how many times you hop you don't make it to the next step. You either make the required minimum or you don't.
Pat
   / Welding - Stick Vs Gasless MIG? #19
-Jer.
For thick stuff like 3/4" you prepare the job by grinding bevels in the gap between the two pieces and then use multiple pass welds to fill up and crown the gap. Grinding and welding go hand in hand.
   / Welding - Stick Vs Gasless MIG? #20
Oh I know that all to well,
I've got a Hobart handler 110 MiG, never tried it with out the gas, I thought that's the reason for MIG, (gas shielding). Found an old thunderbolt AC on the side of the road 30 years ago that I still use most. Went and bought a Honda powered 170 amp dc welder cause everyone said DC was easy???
How do you Guys run your DC welders, electrode+ or E-?
E- is called straight polarity I believe, which sounds contradictory to ac welding, been told that's the way to go but didn't find it any easier.
I don't have much time on the DC machine so I guess I have to practice more.
Been considering a class in welding, would help me I'm sure.
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55302)
JOHN DEERE ROW...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A55745)
2006 V.E...
1994 International F-8100 Roll Off Truck, VIN # 1HTHCAUR7RH595438 (A54865)
1994 International...
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
