Welding tool steel/spring steel
   / Welding tool steel/spring steel
I wouldn't have thought silver solder would be good for a butt joint like that? Not enough surface area? Remember, it is only a strip 3/16x1/4 that contacts. The gun digest I have that features cooper knives said he arc welded them, nothing more. That leaves a lot of room for speculation. I have heard arc welding to refer to all kinds of electric welding. Even if they used it in the normal sense (stick) that still doesn't narrow it down much. Only about 50,000 different electrode type/diameter/current options.
   / Welding tool steel/spring steel #13
I'm not a knife expert but years ago I made a knife from a file and brazed a 1/4" bolt to the end and added many layers of 1/4" leather stacked 'til I had a grip. Sanding with a disk shaped the grip. Buffing and repeated coatings of linseed oil finished the grip.
I still have it and it is razor sharp and keeps its edge. I made the guard with 1/8" shaped brass and threaded a self locking nut on the end to hold the leather grip stack in place.
The brazed on grip rod has withstood many many outings, skinned moose and carved many walking sticks and opened many cans of food stuff.
Only down side is humidity leaves a rusty finish from dampness but that is a minor issue compared to the fine edge the blade keeps.
I also hand crafted the belt case from thick soft oiled leather that simply hangs from a wideish lace or strap. The case covers about 1/2 of the grip so that I don't need straps and snaps.
Since it sort of dangles from my belt, gravity keeps it in the holster ai all times.
   / Welding tool steel/spring steel #14
The guys I talked to Did silver solder theirs..I would still Tig mine if i built knives. try both and see what you get.
2006 TerraGator 8104 (A53472)
2006 TerraGator...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
